Previous in Forum: MV Manhole Spacing   Next in Forum: Resistance of a Transistor
Memory Card Playback
12/05/2013 10:57 PM
I can't get the recorded music to play in my Tech/Pro amplifier ...Do i need to initialize the card and start over or is their something i am missing in the details The state of the game is that the Dealer will take it back but i just think i need a bit more knowledge. As it is the card just remains totally silent While the same card plays beautiful music from the Tascam DP-004 multi-track recorderthru the same Tech/Pro amp It's a real simple problem that i have racked my mind about please help John
John DeLaney
Pathfinder Tags: memory card lost it's mind
Re: Memory card playback
12/05/2013 11:51 PM
The answer lies within your original offering.
You must search deeply to find the truth and reach the end of your journey to the perfect sound card.
It could be that the Tech/Pro amplifier has been offended by your vibes.
It could be that the moon was not in the right orbit, or the sun was not yet over the yard arm, or you are just goofy.
You gotta know when to hold 'em, know when to fold 'em, know when to walk away, know when to run. (Kenny Rogers)
Good Answers: 70
Re: Memory Card Playback
12/07/2013 3:09 AM
It sounds like the Tech/Pro amplifier is missing the other 42 tracks that the Tascam DP-4 multi-track is reading. It could be that Tech/Pro amplifier operates with closed gates where as Tascam DP-004 operates with open gates thus letting the beautiful music play thru
12/07/2013 9:04 AM
It's the Golgafrinchans, they're at it again.
12/07/2013 12:56 PM
A few thoughts. Are the sound tracks recorded as .mp3 files, not some other format? Is the card not greater than 16 Gb in size? Is the input switch turned to the correct position? Is there something in the user manual about it? (The user manuals do not appear to be available online.)
12/10/2013 11:56 AM
Tech/Pro amplifier doesnot define
there are different types of momory cards even with the similar sockets/pinouts
it might be your undefined doesnot support this particular 1 - read man tech specs (ask a friend's friend's ... friend)
ci139
ci139 (1); dj95401 (1); lyn (2); phph001 (1)
