Previous in Forum: Shoe Footing Design   Next in Forum: Should Have Checked Those Soil Conditions Before Building!!
Water Treatment
12/09/2013 10:35 PM
Any one has experience of using the REVO Plus system of Ranhill, Malaysia in Water treatment? Will be glad if people with experience share the pros and cons of the system.
regards
Re: Water Treatment
12/09/2013 11:03 PM
Re: Water Treatment
12/14/2013 4:11 PM
Ah Lyn, As usual a value added comment. Keep up the good work.
Re: Water Treatment
12/10/2013 8:18 PM
Is this a Reverse Osmosis system? Do you have link to website, or can you post a spec sheet?
Generally the Pro's vs Con's, all depends on the suitability of the solution to the specifics of the source water. Can you also describe the feed water you need to treat? Detailed water analysis would be good. Also what do you need the trteated water for (drinking, industrial process, etc.).
Cheers,
Anthony
Register to Reply 3 comments
ajwinemaker (1); Anonymous Poster (1); lyn (1)
