Previous in Forum: About the Corona Ring   Next in Forum: Neutral Current Transformer Polarity
Minimum Dimension for Busbars in 20kV
12/30/2013 7:07 AM
The minimum size of copper conductor in 20 kv is 35mm2. Could you please tell me the minimum dimension of bus bars that we can use for 20 kv. For example can we use 30*5 mm in 20 kv.
Thank you for your help.
Re: Minimum dimention for busbars in 20KV
12/30/2013 8:31 AM
If you knew How to Search the Internet - Hannon Library you would know these things!
Medium Voltage technical guide - OPS Schneider Electric
MV design guide - Schneider Electric
Re: Minimum Dimension for Busbars in 20KV
12/30/2013 2:06 PM
Here is further literature on copper bus bar design. Your local electrical regulations may also specify.
Register to Reply 2 comments
