Previous in Forum: Double Sliding Mechanism for a Boats Bucket Seat   Next in Forum: Compressor Efficiencies
Material Composition 513 Grade D
01/02/2014 9:17 AM
material composition 513 grade d and its equivalent DIN standard/ JIS stadard
Re: Material Composition 513 Grade D
01/02/2014 9:32 AM
India - Member - Mechanical Engineer Engineering Fields - Petroleum Engineering - Mechanical Engineer
01/03/2014 1:09 AM
Kindly be specific
Is it ASTM A513 or IS 513, since ASTM A513 is Standard Specification for Electric - Resistance -Welded Carbon And Alloy Steel Mechanical Tubing while IS 513 is Cold Reduced Low Carbon Steel Sheet and Strip and unfortunately to the extent I have checked both do not have any grade D. So confirm what 513 it is so that we can help you.
Varun Passi
Register to Reply 2 comments
