Previous in Forum: Register to Reply   Next in Forum: Reply is Being Not Processed
Why Can't I Reply?
01/03/2014 8:12 PM
Dear Sir:
I have start a discussion recently, and many experts gave me many good and useful suggestions, I want to discuss with them further and say thanks , but I found sometimes I cannot reply.
The message is Could not process form: The system was unable to process this form.
why? what is the matter? I mistake sth?
Weijunmei
Re: Why can't I reply:
01/03/2014 8:18 PM
Your reply page is timing out......copy post before you click on submit, if post fails, hit back button on browser 3 times er so, and paste in new reply......
Good Answers: 141
01/03/2014 8:59 PM
GA.
1. I think it is done to check the average intellect of the posters.
2. A special, secret program that is put together to test feedback.
3. A measure taken to preserve bandwidth, to not have too many posts open all the time.
4. A quality test to see if you have the strength, guts, courage to re-type it a lot faster and try again.
5. and not being able to have your form processed again.
6. We all went through it.
Plenty of room here
01/03/2014 10:35 PM
When this happens, hit the "back" arrow of your browser and the previous screen will appear. Paste and copy your reply into a new reply window.
All will be well.
Compliments of a fellow member, dvmdsc.
01/03/2014 11:15 PM
thank you all.maybe the iexplore problem.i try with my pad. it is ok now.
01/04/2014 3:15 AM
The iPad does it too, I just cannot type as fast.
Good Answers: 203
Re: Why Can't I Reply?
01/05/2014 12:46 PM
veijunmel-
Make it even better by using a good spell checker!
Do your reply in Microsoft Word or another word processor. Spell checks it with their spell checker (many mistakes found by the WP, CR4 doesn't pick up). Highlight the WP text, start a reply in CR4, drag the text to the reply box, de-highlight the text and proceed as you normally would.
If CR4 doesn't come up with: "Could not process form: The system was unable to process this form, at the most it takes 10-15 seconds more. If it won't process it saves you more than 3 minutes to do it any other way. It takes only 1 "will not process" to equal the 10-12 times that you could have saved doing it the WP & paste method.
I have done it this way ever since the problem began. I will continue to do it this way, even after it is fixed, because it finds many spelling, typos and grammar errors (areas of my weakness) that CR4 doesn't pick up. I have tried others and they are not as quick and all-inclusive as this is. 10-15 seconds is better than 3 minutes!
Note- 3 errors were found by the WP spell checker on this original! CR4 didn't find any of them.
Good Luck, Old Salt
01/06/2014 5:31 AM
Dear Sir: Thank you very much for you kind help! i will try itnext time and give you my feedback! best regards
Register to Reply 7 comments
dvmdsc (1); lyn (1); old salt (1); OscarPhilips (1); SolarEagle (1); weijunmei (2)
