Dear sir,
I want to control the direction of my drive from a single input to three terminal output. Three terminals are there in my drive to control it, they are forward, reverse and enable/reset from a single input. In order to control the drive to forward and reverse terminal, the enable terminal must be connected for both.
when 0.66 voltage as input- enable and forward terminal should connect to 24 volt.
when the input voltage is 5 volt- enable and reverse terminal should connect to 24 volt
when the input voltage is 0 volt - none of the terminal should be connected to 24 volt.
pleae some one give an idea of how to make this possible. i cannot differentiate the 0.66 volt and 0 volt. when im trying to make this, my circuit considered the 0.66 voltage as 0 volt but that should not happen in my case. so, is there any other way to distinguish the 0.66 voltage and 0 voltage to switch the circuits? i am thinking of using both pnp and npn transistor and relay for this circuits but dont know how to do it. Please, someone give me the idea to resolve the issues.
Thank you
RAJU.P
