Heard that plane pilots have higher brain cancer occurance, would balded heads have more BC occurance too ? UV rays have increased skin cancer. Could all these be related to the magnetic earth field ? Some paramagnetic elements are present in humans, they could be debalanced causing mitosis, and once it is started, it keeps going untill balanced again. Magnetization memory could be at play here. We know (chemo th. ) (radio th. ) etc, in some type of cancer; how to kill the atypical cells, but we don't know (i hope ...) the reason why this mitosis begins or why it keeps going. A clue to this theory (magnetism) is that when removed (surgery) completely, it has an almost 100 % chance of success, that is if the environment , etc is corrected accidentaly or not. Either chemically or mechanically, our body's chemistry is changed atypically no matter what cancer we get. Stress increases the risk of various cancers, besides the effect on imune systems as observed, stress changes the chemistry of our cells. There could be a parallel and combined effect with paramag. elements in our bodies. There has been studies on continuous c. in power lines that strenghtens my theory. Any inputs on this ?
This theory is a combination of studies i am doing in the durability of permanent magnets and their possible effects in the human body in its use in transportation for example. Insulation will likely be mandatory around elect. motorization.
Thanks.
