Previous in Forum: Sinosidal Vibration On Compressor   Next in Forum: High Vibration Problem in 125 mw KN Series Steam Turbine
9 comments
Vibration from the Compressor Element
01/09/2014 7:33 AM
Please house I need input.After overhauling our GA132 compressor twice and work for just five months.The element is now making an unusaual noise like vibration.What can be responsible for this.
Re: Vibration from the compressor element
01/09/2014 7:56 AM
I have no answer but I am sure there will be some replys.
Let me try to bundle them:
1. what did the call to Atlas Copco come up with?
2. What did you do during the overhauling, was there any help from the supplier, did you follow the correct procedure? Why did you overhaul in the first place?
3. you had the compressor apart two times and should have a general idea whats causing this. We on the other hand side sit far far away and can not hear or see beyond what you tell us.
4. Contact supplier is your best bet
5. Was there any problems with the element before? Was it ever changed out during the overhauls?
6. there would be plenty more to ask. If you want a better answer try to write up a summary about the problem and the history of the compressor so we can think for you what it could be!
By saying that I am sure you already have the answer one way or the other by the time you post next time!
Let us know what you come up with!
Thanks IS
01/09/2014 10:39 AM
Thanks man,the element seize in the first place that warranted the overhauling and the overhauling was done by our third party.
02/07/2014 12:21 AM
Whats the third party saying about this? What was agreed with them in the contract?
Seems there is another perspective to it now.
How did you quality control the work from third party and how did they document their work?
01/09/2014 8:52 AM
Sometimes it's the littlest things.
Did you use a torque wrench, and follow the the exact procedure for torquing everything down?
I don't know if that's it, but I've been bitten by skipping seemingly insignificant details before. Now, it takes me a while to do something, because I triple check every step...but my success rate is much higher.
Re: Vibration from the Compressor Element
01/09/2014 10:26 AM
Vibration per se is not specifically covered, but this is most likely a component alignment problem.
Good Luck
01/09/2014 11:03 AM
What do your readouts tell you?
http://www.youtube.com/watch?v=GsSDTceRMXA
01/10/2014 1:46 AM
what is the implication of using just two compressors instead of three compressor,because the two is still doing the job
01/10/2014 3:23 AM
You are kidding, right?
Few things come to mind!
1. Backup Compressor
2. Continuus service
3. Redundancy
4. Process safety
But then there might be none such thing and a reduced compression rate would be the consequence of your proposal. What that means for you is unknown to us but I can get you some hard guesses if you wish . . .
Good Answers: 122
01/13/2014 9:28 AM
Often the reason for the low cost of using a third party vendor is because there are many "shortcuts" taken to minimize expense/cost of the work that do not meet factory OEM specifications.
Since you have perfromed the repair twice:
The first thing that comes to mind is one of the most simple oversights which occurs often when the original retainer components such as lockwashers, conical washers, shims, bolts, and pins are not replaced with new components.
The initial machine alignment may be performed correctly however the retainers will fail allowing movement of the machine components resulting in misalignment which cause vibration, bearing heating, damage, and/or failure and the costly circle repeats until corrected.
My experience over the years has been that the lowest cost bidder is seldom the highest quality provider of services and you would be best seved at this point to have ATLAS COPCO Field Service perform a tear down and inspection of the unit.
Register to Reply 9 comments
ALOWEI (2); IdeaSmith (3); kramarat (1); LongintheTooth (1); SHOCKHISCAN (1); SolarEagle (1)
