Previous in Forum: Set Gain for Audio Amp   Next in Forum: Samsung LN46A650A1FXZA Repair
8 comments
Question on Streaming Video Through Android Phone on Home Network
01/11/2014 1:28 PM
Hi folks,
I have a question on streaming video through my Android phone via my home network. The question is how do I tell the data is coming through my network connection and not via the cell phone connection. Details as follows:
I have a home network fed by roadrunner via a cable modem and router. Three PCs connect to the router. I recently bought a Sonos wireless speaker and put that on the network. Any PC can run the speaker. I also put an app on my Droid phone, and was able to connect the phone to my home network and control the speaker with the phone.
Now I bought an HDMI cable and can output audio/video of what's on my phone on a flat screen TV. So I can play content from Netflix, Amazon, whatever on the TV via the phone. My question is, if I do this, how do I tell where the data is coming through? Is it coming through my home network, or through my cell phone provider? It matters because I don't do much on my phone other than calls and a little texting, so I don't have much of a data plan. I don't want to upgrade to a more expensive plan and I don't want to find out the hard way by getting a big bill for data overrun a month after I start doing this. I can see in the little icon bar at the top of the screen that the phone is connected to my home network, but I can't tell if streaming data is coming through the network or the cell phone - or how to choose a setting that specifically routes the data through the network connection.
Any advice? Thanks -
jhammond
My aspect ratio is 2.28.
Re: Question on streaming video through Android phone on home network
01/11/2014 1:52 PM
I just checked my Android phone to confirm this. There is an icon called "Tools". If one touches it a help application pops up that explains how to use your phone. Read it.
Good Answers: 141
01/11/2014 2:19 PM
Perhaps switch off one at the time and see what option stops the streaming.
Plenty of room here
01/11/2014 3:29 PM
If you are streaming through wifi there is no data charge....Your phone should be connected to the internet through your cable via wifi.....
Re: Question on Streaming Video Through Android Phone on Home Network
01/11/2014 3:31 PM
If you see the WiFi icon at the top, that means all data is coming in through your WiFi connection. If you want to be sure, you can go into settings and disable carrier network data temporarily. But again if the WiFi icon is showing, it's Wifi being used.
01/12/2014 8:06 AM
Thanks guys, all good suggestions, just ran the experiment. While I was looking at a simple video, I shut down the router. The video never stopped, but the little network symbol disappeared and was replaced by the little 4G symbol. Then it came back when the router was powered back up, and the 4G symbol disappeared. It looks like whenever I come in the house and the phone finds the network, everything - internet, calls, text messages - goes though the network connection. I never knew that. Appreciate the help.
jhammond
01/12/2014 11:27 AM
There is also a settings icon on the Android menu that has option to check Mobile network. If you check this, the phone will always stream data through an available wireless network. You want to check it.
01/12/2014 8:07 PM
Thanks, I couldn't find a setting that looked like that. But I did find Wi-Fi sleep policy under the Advanced settings of Wi-Fi Settings, which said "Specify when to switch from Wi-Fi to mobile data." "Never" was checked. Seems like that would keep me on the home network whenever I am in range, i.e. in the house.
jhammond
Good Answers: 119
01/13/2014 9:06 AM
Being the paranoid person I am, I always put the phone/tablet in airplane mode then turn on Wifi for streaming videos.
Register to Reply 8 comments
dvmdsc (1); Hooker (1); jhammond (2); PFR (1); redfred (1); SolarEagle (1); yamdankee (1)
