Previous in Forum: Question on Streaming Video Through Android Phone on Home Network   Next in Forum: Samsung LN46A650A1FXZA Repair Complete LCD 46"
17 comments
01/12/2014 12:26 PM
So I turn on this tv this morning and all it does is blink the red power light indicator off and on, with an annoying clicking sound....after several attempts to placate the beast, with no success, it dawned on me that the set is about 5 years old and I may have had a cap fail.....so I dismantled the set, and sure enough 2 likely candidates, swollen and discolored....so I pulled the board and removed the caps, only to realize this is Sunday and the local Radio Shack has just opened, wish me luck I'm off in search of a couple of 1000uf 16v caps....
Pathfinder Tags: samsung flat screen repair
Re: Samsung LN46A650A1FXZA repair
01/12/2014 12:37 PM
I've fixed many TVs, including the 52" Samsung I have now (bought for $100 broken on Craigslist) by simply replacing swollen, leaking, or burst-open capacitors.
Doesn't seem like you're asking for advice, but it's worth it to take the time while you have the cover off to check for any burnt out ICs, too. A broken capacitor can sometimes cause an IC to fail, too. Good visual once over should do it. :)
I hope Radio Shack has the capacitors!
Re: Samsung LN46A650A1FXZA Repair
01/12/2014 12:43 PM
...and do re-post after the repair, regardless as to whether it was successful or not. Interested readers deserve to be told.
01/12/2014 12:48 PM
I think you should upgrade...
Good Answers: 104
01/12/2014 1:32 PM
You may be aware of the site www.badcaps.net. I replaced the first bad cap in a 27" Toshiba with one from Radio Shack and later all the others with better quality caps. After several years, the old problem (foldover) is starting to recur, so I may replace the old RS one (weI finally broke down and bought an HD LED flat screen so this one is out of service).
All this to say, Radio Shack capacitors may get you by for a while (maybe a long while), but if you want the best repair, you should probably use higher quality, low-ESR caps. The link above tells which ones folks have had good success with.
Good luck and be careful to discharge all the caps before you start. Some of those babies can store a punch for longer than you might think!
United States - Member - New Member Hobbies - HAM Radio - AC9JZ extra
01/13/2014 12:02 PM
Good point! Be sure to upgrade to high temperature caps as well. Heat is the # 1 killer of caps.
The only dumb question is the one you didn't ask.
01/13/2014 6:33 PM
GA
You beat me to it!!!
High temperature caps are almost always a good bet and tend to last longer, especially in TVs which often after several hours, get pretty warm.
01/12/2014 2:51 PM
update: out of stock, this is the closest they had....contemplating waiting until
Monday to hit electronics supply house....
01/12/2014 2:56 PM
is the voltage rating the same?
01/12/2014 3:03 PM
No the're 35v 1000uf axial mount.....originals were 16v 1000uf....the board is too tight I think to risk it....
Good Answers: 88
01/12/2014 3:37 PM
This switching power supply capacitor issue is in my opinion a low life sc*mbag time bomb, a cheap mechanism to limit the useful life after warranty of most electronic equipment, long before they become truly obsolete. If addresed before the equipment is totally fried by unclamped HV spikes, it can be "easily" solved by e.g. adding a small inductance in series just after the HF rectification and before the dying caps. I also add a couple of 50V .1uF multi layer ceramics in parallel with bigger electrolytics, check for any cooling issues and forget all about it. Power supply will outlast other damaged stages from other design "flaws". S.M.
01/12/2014 5:14 PM
I'll settle for a couple of bullet proof capacitors....
01/13/2014 12:34 AM
G'day Solar E The cap. shown would be quite OK As long as you install it with the +ve down and put a strip of spaghetti over the exposed negative lead. Of course an RB type will fit in without this Mod.
We have almost finished with Monday over here, will send it over to you....
Regards,
Rod. J.
01/13/2014 11:40 AM
DONT FORGET to get the right Temperature rating for the caps. they being in the power supply in a low vent can, they will get warm and need to be the hi temp types. otherwise you will be back at RS very soon. Theres nothing wrong with going a little oversize in uF so long as they physically fit, but I say again they MUST be hi temp's.
01/13/2014 12:07 PM
Sorry LongintheTooth, I did it again, forgot to reread all comments. I meant well, in replying about upgrading the caps.
01/13/2014 12:13 PM
no problem; I wont get a GA anyhow lol.
01/13/2014 11:58 AM
I agree with yamdankee, but would also check the other boards for shorts, especially the Backlight Inverter Board. Once the caps start failing, filtering and regulation are poor, possibly sending surges to other boards. Best to use a meter, visual is good, but may miss an obvious short. Before you spend much time changing components, many boards are available at reasonable cost, with a full warranty. Did you count the blinks and check the error code? Good luck,, but then skill surpasses luck, and you seem to be on the right track. Let us know how it comes out!
01/14/2014 11:09 AM
Register to Reply 17 comments
Andy Germany (1); bigg (1); Fredski (2); Jacko the Aus (1); LongintheTooth (2); Mike Proctor (3); PWSlack (1); SimpleMind (1); SolarEagle (4); yamdankee (1)
