Previous in Forum: How to Find Fault in House Electric Wiring   Next in Forum: ACS800 ABB Drive Precharge Circuit Configuration
DC Drive Conversion
01/13/2014 11:30 AM
Can i run DCS500 drive ( ABB) with control board CON-4(DCS800) , if yes then what parameter and hardware required to change
Pathfinder Tags: DC Drive
Good Answers: 444
Re: DC Drive conversion
01/13/2014 11:47 AM
The only accurate source of that type of information is ABB. Although others may have experience with those part numbers; interchangeability of the boards may depend upon hardware, software and firmware revision levels, things that only the OEM can verify.
Pick up the phone and call them.
01/18/2014 11:29 AM
What is a phone?
Good Answers: 42
Re: DC Drive Conversion
01/13/2014 11:51 PM
Upgrading the drive would depend largely on the HP of the drive. Under 400HP it is not worth your time or energy.
For retrofitting larger drives http://www.asi-ltd.ca/products/InterfaceBrochure.pdf
so it is quite possible.
Register to Reply 3 comments
GW (1); Munster (1); RAMConsult (1)
