Has anyone run across the pre-charge circuit for the ABB ACS800 drives?
Specifically the ACS800-04-030-07 model.
It will be used on a common DC bus and I want to verify that everything will work as planned when the drive is "racked in or out". The ABB papers I have read do not give even a thumbnail overview, just a lot of cautions.
The concern is the external UDC+ terminal does not connect directly to the capacitor bank, UDC- does. Is there an internal relay or some circuit that allows some precharge before full voltage is applied to the cap bank? 690uF dropped across a 900v bus would cause significant inrush.
