Previous in Forum: ACS800 ABB Drive Precharge Circuit Configuration   Next in Forum: Will a Flow Battery Power Your Home Soon?
Motor Air Flow Sensor (Vent Captor)
01/14/2014 4:42 AM
Do you know any supplier for air flow monitor (vent captor), used inside dc motors for cooling protection? It should be a small plate switching a contact when cooling air flows inside the motor. Thanks
...anything that can go wrong will go wrong...
Re: Motor Air Flow Sensor (Vent Captor)
01/14/2014 7:58 AM
01/14/2014 1:53 PM
Use a motor with a thermistor instead. It would be no good if air at 300degC were flowing past the switch, would it (rhetorical question - NNTR)?
Register to Reply 2 comments
