Previous in Forum: Blower Calculations   Next in Forum: Mechanical Engineer
13 comments
Brushes for a Black & Decker Leaf Hog Blower/Vacuum
01/14/2014 4:54 PM
what kind of brushes do I need for a black & decker leaf hog blower/vacuum that has a Johnson U-9835 electric motor made in China. I can find any information on it.
Re: retiree
01/14/2014 5:24 PM
These parts may be hard to find. They are "throw-away" motors.
Someone here may help you.↓
If you have the motor apart, a picture of the brushes would help.
Good Answers: 141
Re: retiree
01/14/2014 6:32 PM
There must be similar brushes in different brand motor.
Use carbon ones. You can always adjust the dimensions. I do it with a sandpaper, on a flat surface and sliding the brush over it in the longitude direction, while measuring the size with a caliper. A sandpaper of 200-250 grit goes well. If you want a smooth finish end with 400 grit. Be careful, because they are softer than you might anticipate. Do it with long strikes and divide the pressure equally when moving. A file works also but is more messy.
Plenty of room here
Good Answers: 104
Re: Brushes for a Black & Decker Leaf Hog Blower/Vacuum
01/14/2014 8:10 PM
McMaster-Carr has some, but they're kind of pricy for cheap tools. eBay has some cheaper, search 'carbon brushes.' As dvm said, you may have to modify them a little, but it's no big deal. You can even re-use the old springs if you have to, or change the length, since they are soldered together. Make sure you fit the contact area to the armature and wipe off the loose carbon before installing them. BTW, I've noticed HarborFreight and other Chinese tools are including spare brushes more often now.
01/14/2014 10:18 PM
Find a distributor....
http://www.johnsonmotor.com/en/index.html
You should be able to order replacement parts where you bought the blower....They should have the part numbers....
01/14/2014 10:39 PM
I have built new brushes 4 times for a universal AC motor which is probably what you have in the blower. I just bought a rod of carbon and had at it.
Here is the history of the last session. Don't worry that it starts out talking about a strange bolt, it finally gets down to the details of the brushes I had to make.
http://cr4.globalspec.com/thread/82791#newcomments
It was burning when I put it down!
Good Answers: 25
01/14/2014 11:53 PM
Many True Value hardware stores have a large assortment of bolts, screws, and LOTS of miscellaneous, well, hardware. Usually one entire aisle is taken up by the display. Among the many, many things in the assortment are carbon motor/generator brushes, and they aren't very expensive. Get some which are slightly larger in every dimension than the ones you are replacing (if you can't find an exact match) and sand them to size as described above.
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
01/15/2014 6:10 AM
I've made brushes out of the carbon rods found in "D" cell flashlight batteries.(living north of 60 neccesitates creativity at times....)
Nothing is fool-proof to a talented fool
01/15/2014 7:49 AM
Try Helwig carbon products in Wisconsin should be able to help and you cane get extra brushes for down the road repairs
01/15/2014 8:21 AM
GA. That explains the difficulty in finding brushes.
Good Answers: 104
01/15/2014 10:58 AM
Not really. You can definitely see the commutator in the picture he provided . Surely, it also has brushes.
01/15/2014 11:16 AM
Then I wish the OP luck in his quest.
https://en.wikipedia.org/wiki/Brushless_DC_electric_motor
01/15/2014 12:54 PM
Universal AC motors will run on DC and really have brushes.
Good Answers: 12
01/16/2014 3:23 PM
With B&D I usually refer to the manual for part numbers. I have also found the manuals on the Black and Decker web site (if I don't have it). Although I have not needed brushes, so that might be a horse of a different color.
Bill
Register to Reply 13 comments
bigg (2); dvmdsc (1); Ed Watts (1); jamietx (1); kramarat (2); lonster (1); lyn (1); mrehmus (2); Sciesis2 (1); SolarEagle (1)
