Previous in Forum: Slab Design   Next in Forum: Depth of Frost GRP Pipe
Insert Plates for Cantilever
01/17/2014 11:24 PM
INSERT PLATE RECEIVED FOR THE ERECTION OF CANTILEVER (8mtrs.long & 27T)
HAVE WELDED HOLD FASTS OF TOR STEEL Fe500, UNFORTUNATELY HOT BEND IN C SHAPE. WILL THIS HOT BENDS WILL REDUCE THE STRENGTH OF HOLD FAST, IF YES WHAT IS %.
Re: INSERT PLATES FOR CANTILEVER
01/18/2014 4:46 AM
Shouting does not make that question any more sensible than not shouting.
Good Answers: 179
Re: Insert Plates for Cantilever
01/18/2014 1:46 PM
Insert plate?? You're talking a totally different structural engineering language than I know of......Frankly, Ive never heard of that terminology before used for cantilevered beams.
What is Fe500, a non-USA steek grade? What country is it used in?
A photograph is worth a thousand words. So is concise clarification.
Good Answers: 114
01/18/2014 5:42 PM
Fe 500 is, I believe, an Indian designation for rebar with a yield of 500N/mm2 . It sounds as though he is fabricating the insert plate using rebar for anchors. The channel is a mystery.
CaptMoosie (1); passingtongreen (1); Tornado (1)
