Previous in Forum: Silicon Purity   Next in Forum: Turbine Efficiencies
18 comments
Weight of Copper in Copper Cables Per Meter
01/19/2014 8:45 AM
pl give weight of copper per meter of following size SINGLE CORE copper cables
300 SQmm
240 SQmm
150 SQmm
185 SQmm
Re: weight of copper in copper cables per meter
01/19/2014 9:19 AM
Please learn how to search the internet.Save us all a lot of wasted time and bandwidth.
01/19/2014 11:32 PM
Your answer is really bad !
If you do not like to furnish a feedback ....... do not reply!
Register to Reply Off Topic (Score 8)
01/20/2014 1:25 AM
Did you follow the link?
01/19/2014 9:21 AM
If you knew How to Search the Internet - Hannon Library as JohnDG said you could independently find How heavy is a copper core per mtr/per mm2 without the insulation ...
Really, it's no more difficult than it was to find this site!
01/19/2014 10:15 AM
does your instructor know you're a cheat?
01/19/2014 12:52 PM
Homework? Might be.
Sounded more like someone who has come across a quantity of wire (by means and methods unknown), and wants to know about how much money he might get from a scrapyard.
300mm? YIKES! According to the info I have, this is the largest available solid copper wire size... wonder where he scored some of that?
01/19/2014 6:32 PM
Any train (or RTS) delays round your/his way?
BTW - UK scrap copper wire fetches about £3.50/kg. CBA to work out price/metre for this guy.
01/19/2014 6:54 PM
I doubt that ashoksoni and Doorman hail from the same part of the planet.
Nor the same intellectual circles either.
Ironically, unless the OP has learned How to Search the Internet - Hannon Library he probably still doesn't have his answer.
Neither link gives a direct answer.
01/19/2014 7:01 PM
Agree - just making a facetious point. Somehow think this is OP's first and last post on CR4.
01/19/2014 7:07 PM
I'll drink to that!
01/19/2014 10:47 AM
Well I don't know what that size copper cable weighs, but it weighs about twice what aluminum cable does....
http://www.interstates.com/img/site_specific/uploads/Aluminum_vs_Copper.pdf
Good Answers: 203
Re: Weight of Copper in Copper Cables Per Meter
01/19/2014 10:58 PM
I goggled "weights of metric wires" to get the answers. It came up with 11,100,000 answers in 0.39 seconds. Those are better odds than that test you are taking and want help on.
What did you goggle to get your answers?
My answers were at http://mdmetric.com/tech/wirewt.htm
Seek Goggle and thee shall find.
Good Luck, Old Salt
01/19/2014 11:04 PM
Interestingly enough ashok found us. Makes one wonder, doesn't it?
01/19/2014 11:37 PM
I think it's time for a colorful metaphor.
01/20/2014 5:33 AM
300Sqmm26.88Kg
240Sqmm21.504Kg
150Sqmm13.44Kg
185Sqmm16.576Kg
devitg
01/20/2014 6:17 AM
Close - only about x10 too heavy!
01/20/2014 6:33 AM
Bad of me , I use 1000 cm for a meter , sorry and thanks for note it
300Sqmm2.688Kg
240Sqmm2.1504Kg
150Sqmm1.344Kg
185Sqmm16.576Kg
devitg
01/20/2014 8:51 AM
Looks like the blind are leading the blind.
Aided by the rude.
Register to Reply 18 comments
devitg (2); Doorman (1); Fredski (1); JohnDG (5); lyn (5); mansuralaa47 (1); old salt (1); SolarEagle (1); StandardsGuy (1)
