Previous in Forum: Equivalent Indian Standards to Chinese Standards   Next in Forum: Mechanical Movement – Doubts…
Corn Stove
01/20/2014 10:14 PM
Hello,
I just got a cornstove and it not getting ant hotter than 160 degrees, I think it has to do with my vet duct. the vent is 3 inch and gose from my stove to my fire place dampner. ive tried everything I can think of with the same results.
Re: corn stove
01/20/2014 10:29 PM
Open the damper?
Where is the smoke going?
What have you tried?
What size is the opening on the stove?
Never had a pellet stove, myself.
DID YOU READ THE INSTRUCTIONS?
Re: corn stove
01/20/2014 10:48 PM
Most of these are forced ventilation....are your fans working....if you don't have forced ventilation then you rely on updraft to ventilate the burner, you should have at least 5 ft of vertical run to induce draft....
http://en.wikipedia.org/wiki/Pellet_stove
Re: corn stove
01/21/2014 1:32 PM
thanks I do have a draft vent, and that is what was puzzling me. I ran the flex as directed but knowing how wood burns I could tell the corn stove was needing more air because with the flu on the stove open all the way it still wouldn't get to full temp and of course I have a slow draft fire place where the dampener is front of fire box. I was thinking of sleeving the chimney with 6 inch from the top down and then run the 3 inch all the way up and out since the corn stove pipe doesn't get that hot and that would be a smaller area to heat for the drafting. I did not know that you need at least 5 ' to induce the draft now I know. I guess it back to work.
Anonymous Poster (1); lyn (1); SolarEagle (1)
