Previous in Forum: Corn Stove   Next in Forum: Hydraulic Pipe Bending Machine
9 comments
Mechanical Movement – Doubts…
01/21/2014 7:18 AM
'Manual of Mechanical Movements' by Mr. Henry T. Brown having 507 mechanical movements was an early compilation, it is still regarded as an interesting reference.
I have taken up the assignment of animating some of the movements presenting in this book.
While so, the below referred movement number: 30, as in the book appears:
The text says, "Rectangular gears. These produce a rotary motion of the driven gear at varying speed. They were used on printing-press, the type of which were placed on a rectangular roller."
I like to discuss on the following two points as to have more clarity towards a perfect animation output:
  • For this type of gear pair, the 'center distance' cannot be constant. At least one wheel has to accommodate the slide of center distance.
  • Presuming the smaller gear is the driver, what kind of movement expected on the driven wheel? The author of the book says, 'varying speed', would this be intermittent rotation (alternately rotate and stand still) or alternately rotates at two different angular velocities within and each rotation?
Pathfinder Tags: Mechanical Movements
Re: Mechanical Movement – Doubts…
01/21/2014 8:01 AM
I'll vote for alternately rotates at two different angular velocities within and each rotation.
Good Answers: 114
01/21/2014 9:22 AM
I think yesyen is correct about the illustration in his post, and you are correct about the illustration in your post. The radii in your picture are much bigger in proportion to the overall size and this allows the gears to stay engaged without moving the axes. This is not true of yesyen's gears
01/21/2014 10:44 AM
I think they will stay engaged in both cases.
As the smaller gear face contact area recedes, the larger gear face contact area will be moving closer, so they will remain meshed.
I think.
Good Answers: 94
01/21/2014 9:19 AM
These are even weirder, (skip to 0.38).
01/21/2014 10:12 AM
01/21/2014 10:57 AM
When I look again at the drawings I think the OP is correct. Even though I posted a video of someone who had made working gears of that general shape, the gears in the OP illustrations are different in important ways.
The squares in the OP illustration are noticeably different in size from one another. More importantly, the number of teeth on the larger square is greater than the number on the smaller square. This means the alignment will shift away from the corner-to-face arrangement it had in the illustration, to a corner-to-corner alignment which will definitely cause a difference in center distance....if it doesn't first slip as it approached face-to-face alignment.
Good Answers: 104
01/21/2014 10:22 AM
See this
Also, the 507 mechanisms has been partially animated. If you search the intenet, you will see that many mechanisms have been animated. Start by Googling 'animated mechanical mechanisms'
Good Answers: 114
01/21/2014 4:40 PM
For this to work, the sum1 of the diagonal of the left square, plus the perpendicular of the right square, must equal the sum1 of the perpendicular of the left square plus the diagonal of the right or they become disengaged at some point.
1. Allowing for the curvature and overlap of the teeth.
01/22/2014 1:35 AM
I take your points after verifying on the board, if only both the gears of same size.
For different sized gears (diameters), on board they have interference (one eating into other) on rotation, which means in real they would get locked-up, unless the centers are allowed to slide. Am I right in saying this?
Register to Reply 9 comments
bigg (1); lyn (2); Nigh (1); passingtongreen (2); truth is not a compromise (2); yesyen (1)
