Previous in Forum: Mechanical Movement – Doubts…   Next in Forum: Issues Running Hydraulic Cylinders In Parallel?
Hydraulic Pipe Bending Machine
01/21/2014 12:49 PM
Hi all, I am trying to work out on the fabrication of an Hydraulic Pipe bending Machine ... on this regards, there are different types of hydraulic cylinders in the market, to select one I should know the amount of force required to bend the considered pipe, for that i need to know the force to bend the pipe of required diameter, while going through some of the fundamentals I came across
Max bending stress (at support) due to bending σ = W·l/Z.......(1)
Where W = FORCE
l = length from support to load
Z = section modulus of pipe = (pi/32)(D4 - d4)/D
where D = outside diameter of pipe
d = inside diameter of pipe.
here my question is in the eq....(1) i have two unknowns stress and force so how should I proceed further... ???
Re: Hydraulic Pipe Bending Machine
01/21/2014 1:21 PM
There are simple shareware programs that will give you a reference that I tend to use.
BeamBoy is one, just establish you pipe size, Material Properties, supports, force and force location, and look at the bend or deflect results. This will give you a good reference and force required.
You also have to realize the quality of your product, such as are you going to use an internal mandrel to limit deformation.
There are other actual forces may be difficult to calculate, such as pushing the mandrel through. but not impossible.
01/21/2014 1:26 PM
You can look up the yield stress for the pipe material, use that value for σ, and then calculate W.
Then maybe multiply by say 1.25 as a service factor.
Good Answers: 183
01/21/2014 1:54 PM
The equation is valid ONLY for elastic deformations. When you bend a pipe most of the section is loaded in the plastic domain and a small section in the elasto-plastic domain. For both the equation is NOT valid. I have also the feeling that suggested soft is limited to the ealstic domain.
However it is possible to define a relationship based on the material properties, on the tube dimensions and the ratio between the mean tube diameter and the mean radius after bending. The results depend on several factors as material behavior in the transelastic domain, the temperature (value is not same at -20°C and +30°C for instance), the tube guide profile (because of lateral friction since the tube becomes oval and presses on the guide) and so on.
I know this because years ago I worked with a company which had as product also pipe benders and participated at different discutions when results were not corresponding to expectations.
Even if you make good calculations you will be obliged to make several tests and correct the theory according to empirical results.
For the start you could consider that after the yield point the stress in the tube stays constant. It is not true but the equivalent of the Young modulus in the plastic range is small and it will be a good approximation.
Good Answers: 141
01/21/2014 2:04 PM
We have many types and makes of hydraulic pipe benders on the market. From simple manual sets to CNC automatic production devices.
Is your pipe that special, so existing machines cannot handle the job?
If yes, better specify the pipe: diameter(s), material, wall thickness and more specifics, so that our guess has some window to think in. Or are you a machine builder?
Plenty of room here
01/21/2014 2:07 PM
I thought it may be school work, considering we just has something similar.
Hydraulic Tubing Bender and Fittings
01/22/2014 9:21 AM
HI to all ... thanx for all ur valuable suggestions .. i'l go through all my errors.... hope i could arrive to correct conclusions ...
Register to Reply 6 comments
dvmdsc (1); nick name (1); Ninja (1); phoenix911 (2); Tornado (1)
