Previous in Forum: Profibus communication cable   Next in Forum: Sony Xperia Ion
8 comments
Battery Holder
01/22/2014 6:13 AM
I need a side loader battery holder for the CR 2032 coin battery that is about 0.125" overall height. I know they have them that are 0.170", but I need one that is around 0.125" Anyone know or have an idea where I can find this ASAP? Thanks
Re: Battery Holder
01/22/2014 6:51 AM
The CR2032 is 0.126" thick (3.2 mm), so you're going to have to modify your requirements.
Other button-cells are available with a thinner profile:
http://en.wikipedia.org/wiki/List_of_battery_sizes#Button_cells_-_coin.2C_watch.2C_micro.2C_miniature
Re: Battery Holder
01/22/2014 7:10 AM
Thanks - what I am looking for is side loader battery holder that is 0.126" (3.2)mm the only thing I can find so far are ones that are larger than 0.126".... have any ideas?
Re: Battery Holder
01/22/2014 7:48 AM
Nintendo NES - Nintendo Repair Hut
Re: Battery Holder
01/22/2014 5:00 PM
This is good, but I need to be able to change the battery. Since our design is low profile, I am looking for a smaller battery holder. Thanks
Re: Battery Holder
01/22/2014 5:23 PM
With this battery, what you want is impossible.
Re: Battery Holder
01/22/2014 11:45 PM
I measure a new, unused, 2032 as 0.123" thick (0.1275" including a 0.0045" layer of plastic to avoid shorting the battery). In order to make reliable contact, the battery holder must be made of metal around 0.010" thick, top and bottom, so the minimum thickness of battery with holder would be 0.143". It is standard practice to have some bends in that metal to provide spring and facilitate insertion of the battery. This brings the minimum thickness to around 0.150".
If there are non-conducting parts of the structure that support the metal and provide spring, you could conceivably get away with thinner contacts, say 0.002" each, allowing the battery and its contacts to fit in a 0.127" space, not counting that supporting structure...
Re: Battery Holder
01/23/2014 4:55 AM
Re: Battery Holder
01/23/2014 5:13 AM
I think that you have two options, build your own battery holder using thin springy, stainless steel or go for a CR2016 (20mm wide, 1.6mm thick) battery that needs more frequent replacement, but is only half as thick....but same voltage.
Or both!!
Register to Reply 8 comments
Andy Germany (1); dkwarner (1); lyn (2); pantaz (1); Randall (1); Santa800 (2)
