Previous in Forum: Camera query   Next in Forum: Internet Range
15 comments
Amplified Radio Signal Without a Capacitor?
06/11/2007 4:12 AM
hullo guys. what would happen to an amplified radio signal if the capacitor in the output channel of the amplifier was removed?
Re: transmission
06/11/2007 8:15 AM
It really would depend on what that capacitor was doing there...
It could be supply decoupling, dc voltage blocking acting as a resonator...
Have you a circuit diagram of this amplifier?
The capacitor was designed to be in there for a purpose so if you remove it you will effect the operation of the amplifier, but in what way is impossible to tell without a circuit.
John.
Re: transmission
06/11/2007 8:55 AM
Hi Electroman!
...while you are answering that question, how about some more?
What will happen if I remove the keyboard from my compu
Re: transmission
06/11/2007 10:22 AM
LOL @ Del
Good Answers: 101
Re: transmission
06/11/2007 11:53 PM
Your computer will not start up because of keyboard error.
Re: transmission
06/12/2007 2:47 AM
Sorry I can't reply...'cos my computer won't start up....
Re: transmission
06/12/2007 5:39 AM
whats a keyboard
Out Of The Inner Circle
Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Automotive Engineering - ChemE in a ME world
Re: transmission
06/12/2007 7:52 AM
can all of you see how easy a blog can spiral out of control!
No matter how far you have gone down the wrong path....Turn around!
Re: transmission
06/12/2007 10:18 AM
Re-install the capacitor, spiraling will stop right there and than!!!
Wangito
Never trade luck for skill.
Re: transmission
06/12/2007 1:36 PM
capacitor is for ac coupling in an amplifier such amplifiers are called rc coupled amplifiers
the resistor at the collector and the capacitor at the o/p serves as the coupling elements.if the coupling capacitor is removed the dc comonent of the voltage gets added up making disturbances in nxt stage amp(drift in bias).In the case of giving the o/p to a loud speaker we use capacitor for bass boosting ( i think so anybody have some objections,pls reply to the forum).
Re: transmission
06/12/2007 1:41 PM
sorry ,for replying to this forum as a guest!
Re: transmission
06/12/2007 1:43 PM
removing the coupling capacitor increases the bandwidth of the amplifier .It increases the response at lower frequencies.
Re: transmission
06/12/2007 2:47 PM
How do you know its not being used as a power supply filtering capacitor, or as a tuned circuit element?
If its used as tuning element in an if strip then it most definitely won't increase bandwidth or the low frequency response...
John.
Good Answers: 59
Re: transmission
06/15/2007 5:27 AM
Output capacitors in audio amplifiers can be used for two purposes:- DC isolation so that you don't get DC currents offsetting the position of the cone of your loudspeaker (and possibly overheating the loudspeaker coil and the amplifier output stage as well), or
Reducing the low frequency output - as in a crossover network, or to protect a physically small loudspeaker from amplifier overdrive (similar input levels cause small loudspeakers have to move further at low frequencies)Generally the effects are combined.
Capacitors in RF stages similarly provide DC isolation to protect both the drive and any externally connected equipment; of course they also provide low frequency blocking. But in many cases they also form part of the resonant circuit that allows the amplifier output impedance to match the impedance of the driven cable (transmission line) or antenna.
Fyz
Re: Amplified Radio Signal Without a Capacitor?
06/13/2007 3:42 AM
Assume the capacitor mentioned is the one connected between the out put of the active element (say, collector of a power transistor) and the speaker. If this is removed, there are chances that your speaker will burn! This is due to the reason that the capacitor provided in this case is to block the DC flowing from the collector of transistor to the LS at the same time passing the amplified alteranting signal.
Cheers!
06/15/2007 7:57 AM
u r right
Reply to Forum Thread 15 comments
Anonymous Poster (1); DVader1000 (1); Electroman (3); Engineer Artist (1); Hap (1); Physicist? (1); ravi00bkp (3); user-deleted-1105 (2); wangito (1); Yani (1)
