Previous in Forum: Altium DXP Routing Strategy For CNC Milling Of Boards   Next in Forum: Tap Rules
16 comments
An EE "Whodunit" . . .
01/31/2014 5:20 PM
Greetings!
I've been mulling over whether or not to post this for a while, and finally decided to "just do it."
<WARNING>The following query is of an extremely simple nature: If one becomes spontaneously peeved, please do not pelt the hapless poster with spoiled fruit items. Please also note that no animal testing was involved during the formulation and/or composition of this post.</WARNING>
The Big Question:
Without resorting to politics, who do we credit with the original elucidation of electric power (P = E X I)? Ohm? Watt? Joule? Al Gore?
Just curious...
(Yep, that's it)
Cheers!
Re: An EE "Whodunit" . . .
01/31/2014 5:31 PM
"The history of electricity begins with William Gilbert, a physician who served Queen Elizabeth the first of England. Before William Gilbert, all that was known about electricity and magnetism was that the lodestone possessed magnetic properties, and that rubbing amber and jet would attract bits of stuff to start sticking.
In 1600, William Gilbert published his treatise De magnete, Magneticisique Corporibus (On the Magnet). Printed in scholarly Latin, the book explained years of Gilbert's research and experiments on electricity and magnetism. Gilbert raised the interest in the new science greatly. It was Gilbert who coined the expression "electrica" in his famous book."
http://inventors.about.com/cs/inventorsalphabet/a/electricity.htm
01/31/2014 5:43 PM
02/02/2014 12:34 AM
I obviously did not read the entire book (it didn't completely download). While I saw many references to the equivalent of voltage and current, I missed any reference to power!
02/03/2014 3:13 PM
As the terms we now use were not yet developed, sending someone to search through Maxwell's retelling of Cavendish's notes is somewhat of a poorly defined scavenger hunt. Sorry about that.
Your analysis is correct (even without the full download). Cavendish notes the direct proportional relationship between his description of voltage and his description of current..... constant resistance is assumed. V = I R
If you are okay with the understood but unstated resistance being slipped in, then Cavendish can be given credit for elucidating P = I V (P = I E). This equation only differs from the one in the previous paragraph by multiplying both sides by the same variable, 'I'.
02/03/2014 3:42 PM
I did just a bit of independent searching, but could not come up with anything real. Since both electric light bulbs and motors were developed somewhat simultaneously during the 1800's, I suspect the concept of electric power developed around the same time. Of course Watt measured power in the second half of the previous century, but I don't believe he used electricity.
It looks like it'll take a real history buff to answer the OP!
02/03/2014 3:51 PM
What? You aren't buying into my assertion based on it being the same equation, merely with both sides of the equation multiplied by current?
Yeah. Me either.
01/31/2014 6:05 PM
Isn't it P=I*V?
Good Answers: 804
02/01/2014 12:13 PM
P = I * V is only for the uninformed who believe it is OK to mix terminology.
E is the designation for Electromotive force, the unit of measurement is a Volt, abbreviated as V
P is the designation for Power, the unit of measurement is a Watt, abbreviated as W
I is the designation for Current (from the French "intensite", thanks to Napolean), the unit of measurement is an Amp, abbreviated as A
So officially, that formula should be P = I * E, or W = A * V, but P = I * V is mixing the terms and should be avoided.
Unfortunately, even otherwise reputable sources screw that up all the time so it perpetuates.
02/01/2014 11:36 PM
I cannot see why this answer deserves a "2" for a "good answer" when it does not answer the question in the original post - which was, " ....who do we credit with the original elucidation of electric power", and worse, that it seems to make much out of nothing.
Electromotive force is not just a force, its units are N.m/q just as they are for volt.
The claim for "mixing of terms" seems to be about some sort of convention that the author prefers, and seems to mix in his own response, and nothing else.
And as to the answer... I don't know but Cavendish seems likely.
02/01/2014 11:58 PM
I'm still trying to figure out what it means to "elucidate electric power".
01/31/2014 6:47 PM
Good Answers: 181
02/01/2014 9:39 PM
I'm retired now.
One of the first things I would give an apprentice was the OHM wheel as you've posted.
There's not a lot you can't sort out with it.
02/02/2014 12:09 AM
I was taught and still say "magic a$$hole"...that's the military for you.
common knowledge...less common than common sense
01/31/2014 9:34 PM
Thanks for the insights -- more than I hoped for...
E? V? One for the record:
http://www.clarkcomponents.co.uk/useful/ohms_law.htm
Better now?
(stretch, yawn)
Nite, nite...
Good Answers: 153
02/02/2014 4:59 AM
The "who" in the question fails to recognise the concept of collaborative effort. There is no "who", there is a "they" that includes all the people who built on each others work to come up with the result. It is like saying that Erricson/Columbus/Vaspuchi discovered America without any help from a few sailors, Armstrong got us to the moon because he was the first to step down, or Marconi invented radio just because a lot of text books say he did.
02/03/2014 12:28 PM
From Wikepedia:
The power dissipated by a linear resistor may be calculated from its resistance, and the voltage or current involved. The formula is a combination of Ohm's Law and Joule's law:
where:
P = power in watts
R = resistance in ohms
V = voltage across the resistor
I = current through the resistor in amps
Any number of people could have been the first to combine these terms. It could have been Ohm, Joule, or anybody mentioned and more. We probably will never know.
Register to Reply 16 comments
dkwarner (2); Doorman (1); Fredski (1); Insatiably_Curious (1); jhhassociates (1); JRaef (1); lyn (1); SolarEagle (1); StandardsGuy (1); The.Tinkerer (1); TonyS (1); TrevorM (1); truth is not a compromise (3)
