Previous in Forum: New Boiler System   Next in Forum: Hydraulic Press Brake Operation (Hydraulic Circuits)
WPS PROCESS
02/03/2014 3:27 AM
What is the process for WPS...????
User-tagged by 1 user
Good Answers: 34
Re: WPS PROCESS
02/03/2014 4:04 AM
One of them..........ASME IX
Re: WPS PROCESS
02/03/2014 4:20 AM
What is WPS???
Tell us and we point you in the right direction!
(Be careful here, people might call you names if you dont reveal yours!)
Re: WPS PROCESS
02/03/2014 4:43 AM
Anonymous Poster #2
Re: WPS PROCESS
02/03/2014 7:10 AM
  • WPS is the short form of Welding Procedure Specification.
  • It is nothing but a collection of certain guidelines to deposit weld metal to get predefined mechanical and corrosion resistant properties.
  • The main variables are essential variables, supplementary essential variables and non essential variables.
  • Essential variable changes would affect the mechanical properties of the weld metal except impact toughness.
  • Supplementary essential variable change would affect the impact toughness of the weld metal
  • Non essential variable changes neither decrease nor increase the weld metal mechanical properties and impact toughness properties.
  • A WPS shall be qualified by a procedure Qualification.
  • The recorded data of the procedure qualification is called Procedure Qualification Record (PQR)
  • A test coupon shall be welded and mechanically tested. Sometimes corrosion tests also shall be conducted due to project requirement.
  • If the test specimen passes all the tests, then you can prepare WPS based on the PQR and applicable codes, specification, standards, contract documents etc.
  • Major codes which help you to prepare WPS are ASME B&PV Section-IX (Boiler, Pressure vessel, Pressure piping), API 1104 (Pipelines), AWS D1.1 (Structural Steel Welding) and EN 15614-1
Re: WPS PROCESS
02/03/2014 8:47 AM
There are plenty of WPS templates out there, review it. But if you have an idea the type(s) of process you'll need, this will make it simpler.
How did you find CR4? Google maybe......
Anonymous Poster #3
Re: WPS PROCESS
02/03/2014 9:31 AM
Western Power Service?
Word Processing System?
Wi-Fi Protected Setup?
Web Processing Service?
World Power Systems?
Good Answers: 137
Re: WPS PROCESS
02/04/2014 6:59 AM
Woman Police Sergeant?
Anonymous Poster (2); Codemaster (1); IdeaSmith (1); JohnDG (1); phoenix911 (1); Whitephone (1)
