Previous in Forum: Cubic Meters Per Second = MPH   Next in Forum: RFID Tags In Credit Cards?
10 comments
Greg's Challenge Question 2
06/11/2007 10:59 AM
Your son has just bought a pressure washer to do some work around the house for you. He says that he will only do the work around the house if you can answer his question correctly. So your son then asks you what would happen if there was a leak in the garden hose which is feeding the pressure washer (while it is in use). Will water leak from the hose, or will air leak into the hose from the atmosphere? Can you get your son to do the work by answering the question correctly?
Once everyone is super, no one will be. - "Incrediboy"
Good Answers: 25
Re: Greg's Challenge Question 2
06/11/2007 11:15 AM
The garden hose supplies a larger volume than the power washer uses so as long as the leak is small no part of the garden hose should experience negative pressure. If a very large leak like a cut or partially severed hose occurred it would be possible for water to leak out and air to enter.
Troy
06/11/2007 11:16 AM
"Will water leak from the hose, or will air leak into the hose from the atmosphere?"
Water will leak FROM the supply hose unless the hose is undersized or the supply valve is not fully open.
06/11/2007 1:20 PM
No. My son are trying to get a way out of doing the work and will trick me so that I will have to do it myself.
"Remember... if women don't find you handsome, at least let them find you handy." - Uncle Red
06/12/2007 2:24 AM
Where comes the water from? If it comes from a dwell then it is a risk. In fact the problem is limited to the question how big is the static pressure at the leak place? Is water pressure higher? it flows out
Is air pressure higher ? it will go in and the pump will cavitate.
06/12/2007 4:00 AM
Dear Greg,
1st. It will leak.
2nd. My son (if I had one!!) would probably pierce the hose to avoid the work!! :)
Best regards,
Abel
"I am NOT an engineer, so I will not create bigger problems to show off..."
06/12/2007 8:17 AM
There is the pressure washer washer, the hose and , the house. To save time and effort in explaining the various things that could happen and the expense of rigging any gauges to test performance, lets just start the job and see if there are any difficulties.
06/12/2007 8:40 AM
I know my son(s) pretty well and I would take his question to mean that 1) he has run over the hose with the lawn mower and cut in two - and 2) he is try to use this as an excuse to get out of pressure washing.
If the hose has been cut in two then I would answer his question like this: The half of the hose that is connected to the spigot will discharge water to the atmosphere the half of the hose that is connected to the pressure washer will draw air in from the atmosphere because the pressure washer is a pump.
Now fix the hose and get to work.
Bob
06/12/2007 10:30 AM
My son would stop wasting time with silly questions and get to work or have a boot in his rear!
06/12/2007 12:26 PM
it is a very modern and progressive educational approach!!!!!!
06/17/2007 5:21 AM
I quess it may depend on the angle of the leak in the hose, if angled with or across the flow you will get a venturi effect and ingress air, but I'm sure it the boy was faced in the right direction and stopped working the angles he's be a lot better off.
Register to Reply 10 comments
Anonymous Poster (4); Chefdechocolate (1); gr8ngner (1); jdretired (1); oomsarel (1); Stirling Stan (1); Troy36 (1)
