Previous in Forum: Smart Building Spies on its Occupants   Next in Forum: current carring capacity
Looking for a Current Source
06/11/2007 11:57 AM
I need a computer-controlled current source, in hundreds of mA, which is solderable by hand. I got a couple from Analog Devices, number ADN8810ACPZ, which are 4x4 mm, and much too small to solder by hand. I'm looking for either a larger part which does the same thing, or if any one knows a way to solder it.
Re: Looking for a Current Source
06/12/2007 9:05 AM
A DAC and a FET or transistor would work. DAC output resolution would accurately control current sourced per input code. Some older DACs can be had in PDIP packages. BJTs can still be had in 3 lead metal/plastic "cans" & FETs are widely available in 3 or 4 terminal D-PAKs.
Soldering small surface mount devices is easier if you use some liquid flux. Flux will allow the solder to flow & stick better to the metal & the chip leads. If you don't use too much solder, you won't have to worry about bridging across the traces either.
This is a very basic & simplistic explanation, but I hope it helps.
06/13/2007 7:07 AM
I agree with guest - take a DAC combined with an OPAMP and a FET.
If you are looking for schematics, look for HOWLAND CURRENT SOURCE and you find simple applicable proposals.
One simple example is
www.elecdesign.com/articles/index.cfm?AD=articleID=9018.
Regards Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
06/13/2007 7:13 AM
sorry - the above link didn`t work, so try this:
www.elecdesign.com/articles/articleID/9018/9018.htm
Uwe
06/13/2007 12:19 PM
If planning for PC control use Tristate buffer like 74HCT573 on Printer port
and use R-2R Resistor network to genrate voltage proportionate to input value,
use it as reference for current source made of descreate MOSFET.
Bharat
Register to Reply 4 comments
Anonymous Poster (1); bharat (1); uweka (2)
