Previous in Forum: Pressure Difference Observed in Pressure Gauge   Next in Forum: Deflection Force from Hydraulic Hose
Ash Conveying
02/13/2014 3:30 AM
Hello everyone!
In our company we are currently working on a system for returning unburnt carbon from fly ash back to the boiler and burring it. We are burning biomass (residues of wood from our production process) all the ash from the flue gases is then collected in a series of cyclones. Through analysis we have wind out that most of the unburned carbon is in the fraction of ash that is bigger than 160 μm (bulk density of this fraction is 169kg/m3).
I am currently doing a preliminary design of the system to find the costs of this project.
My idea is to use a linear sieve to separate the 160μm fraction of the ash and then using pneumatic conveying to transport that ash back to the boiler.
The rate at which >160 μm ash is generated is around 10kg/h. From what I read I should use a 2:1 air to material ratio, so I would need a blower with a minimum capacity of 20kg/h= 16,3m3/h. To get the ash into the conveying pipe I was thinking of using a ventury feed. What is the recommended velocity for ash conveying, so I can size the pipes accordingly? Also what kind of pipes should I use, the ash is very abrasive. The overall length of the pipes will probably be cca 30m with 4m vertical sector and max 3x90° bends.
Is my design good or am I missing something? I have no experience in designing pneumatic conveying systems, so any suggestions would be welcome.
Thank you.
Re: ash conveying
02/13/2014 4:28 AM
This isn't exactly the information you are requesting (I don't have experience with pneumatic conveying), but you might find it pertinent.
Have you studied the actual fuel value of the unburned carbon? The reason I ask, is because in even moderate temperature combustion, glasses tend to form from Si02 Al2O3, CaO, and Fe2O3. These glasses may form a barrier that severely limits any heat that might be obtained from attempting to burn the ash again.
If that does seem to be the case, it might help to run the returning ash through a section of pipe that is acting as a ball mill....turning with hard media inside to crush the glass, exposing any unburned carbon.....
The unburned ash also might have high water content.... not sure, but it would be worth investigating. Burning the ash again could be a good idea, as long as it actually causes more of it to be burnt, and doesn't require extra fuel to be consumed.
Re: ash conveying
02/13/2014 8:10 AM
Do a study to determine the amount of savings this return system will generate for your company, assuming the 10kg/h return rate is a significant enough number compared to the initial fuel input rate.
If the savings is significant enough, hire a mechanical engineer with the proper experience or hire one that can design the system without resorting to asking total strangers for help.
Re: ash conveying
02/13/2014 8:56 AM
Truth is not a compromise
Thank you for your answer. We have done all kind of studies before starting to design this process. From what I've been told from the guys in the lab that were doing the tests, there weren't any problems burning that part of ash. The fuel value is much higher than that of initial fuel (can't remember the exact value though).
Lyn
That's exactly what I am trying to do. But to do that I need to know how much the system will cost us. And to know that I have to contact the vendors to get the prices for all the equipment we will need, so I need to know at least approximately what we will need. Usually we do a preliminary design by ourselves before hiring someone.
Re: ash conveying
02/13/2014 9:04 AM
At this point just take some educated guesses. Err on the high side, so you have a justifiable estimate.
Good Answers: 183
Re: Ash Conveying
02/13/2014 10:49 AM
I noticed that you have cyclones. Is it any difference in form and density (not bulk) between the "carbon rich" ash and the other ash ? If yes iy could be possible to make the separation by "air floating" and adapted cyclones for this kind of operation.
Good Answers: 114
Re: Ash Conveying
02/13/2014 2:50 PM
I can't help with much here but I did learn a thing or two when designing the pipe bridges that carried flyash piping. The lined piping was designed for easy replacement, even to the extent that we included walkways and monorails the full length of the bridges. Sorry, all that tells you is that the piping is high maintenance and that it was lined. I know there were several sources of resistant pipe.
The cross section of the bridge was similar to a soccer goal with a monorail hung directly below the cross bar, and with brackets on the inner side of the posts to carry the piping. Each piping length sat on at least two brackets so that it could stay in place when adjacent ones were removed for replacement. The monorail system ran continuously to a couple of drop zones in the thousand plus yard length of the bridges.
Register to Reply 6 comments
Luka (1); lyn (2); nick name (1); passingtongreen (1); truth is not a compromise (1)
