Previous in Forum: Smog Pollution   Next in Forum: Exciter Shorted
Crane Failure
03/03/2014 6:36 PM
10ton demag overhead crane show error code 63 triangle and 31 lightin, winch dont works either up or down
Pathfinder Tags: Demag error
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: Crane failture
03/03/2014 6:45 PM
It's broken. Contact the manufacturer.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Re: Crane failture
03/03/2014 7:05 PM
Go to page 71 in the operator's manual.
See step # 3. Follow the instructions on making error code 63 regular again. The second step, switch over #2 should read, "turn the #14 code switch off/on/off."
Some manuals have these steps backward, and you will make the winch run backwards, or not work at all, if the sequence isn't correct.
Be sure to record each step and report back to us.
Or, call tech service.
Good Answers: 73
Re: Crane failture
03/04/2014 8:36 PM
Some good info there lyn. However, if you follow step 3, the readout will be in doppelzentners.
Re: Crane failture
03/04/2014 9:07 PM
Oh, well, you must have the German version of the manual. The American version yields mega-henweighs.
Re: Crane Failure
03/04/2014 6:46 PM
Well, the tool needed to fix it is the telephone. Ring the maufacturer and get the local Service Engineer to make a visit.
Bricktop (2); lyn (2); PWSlack (1)
