Previous in Forum: Rotor Earth Fault 1 Causes and Solutions   Next in Forum: Specification of Electric Motor for Electric Bikes
Electric Motor and Shield
03/04/2014 12:27 AM
I am working on a physics experiment and have only used stepper motors. I need to find a 25-30 W motor with a slew rate of 10-20Hz. Of course I expect some gearing to be involved. I need it to be speed controllable with arduino. Sort of drowning in lists right now. I probably need a good introduction to the literature here.
C
Pathfinder Tags: Arduino electric motor Shield
Re: Electric Motor and Shield
03/04/2014 7:12 AM
Your best bet would be to talk to a few suppliers - they'll help you build up a picture of what you'll need, and after the first couple you should get familiar with the terminology and what sort of kit is available.
If you PM me your e-mail address (don't post it it open forum, admin will frown upon it an delete it!) I can send you a useful bit of blurb about motor selection. Click below:
Send JohnDG a Message
03/04/2014 9:25 AM
Superior Electric ( SLO-SYN stepper motors )
has an excellent tutorial booklet on steppers and step controllers.
http://mcsupplyco.com/uploads/Manufacturers/Superior.asp
I expect other stepper manufacturers do as well.
03/04/2014 11:23 AM
Thanks but I was saying that I do not need a stepper motor. I need a simpler AC or DC motor that has good torque density with these parameters.
03/04/2014 11:24 AM
I should have been more clear about that.
03/04/2014 12:51 PM
03/14/2014 5:43 PM
You guys are great. The static I am trying to cut through in all this is to find what type of motors give the greatest power per volume or weight (at a reasonable cost). I sense some of these calculate these densities by neglecting all the other electronics that go to drive the thing. I want a variable speed compact device for a simple application with occasional use and am wondering if the old fashioned brushed DC motor is the best choice.
03/15/2014 7:28 AM
Trident Engineering a good place to browse small motors. Usual disclaimers.
http://www.tridenteng.co.uk/
Register to Reply 7 comments
cchaf (3); JohnDG (2); LongintheTooth (1); SolarEagle (1)
