Previous in Forum: Electric Motor and Shield   Next in Forum: Motor Overloads
8 comments
Specification of Electric Motor for Electric Bikes
03/04/2014 9:23 AM
We are working on the project of solar car. We are using ultramotor of model no. -U002014801800. And we have 4 batteries of 12volt 26AH, is there anyone who can suggest me how much power is required to move the vehicle?
ee.saurav@yahoo.com
Re: specification of electric motor for electric bikes
03/04/2014 9:31 AM
Without telling us how much the vehicle will weigh and other specifications , you will only get wild ( and unhelpful ) guesses here.
Try doing a little more work in design to establish some more parameters with which to work. Then post again .
03/04/2014 12:36 PM
You match the batteries to the motor, then amp hours tells you how long it will last....So if you have a 1000 watt motor@ 48 volts then it would be watts divided by volts gives you the amps required....ie; 1000w/48v=20.83A So you would need 21A per hour....so with this scenario your batteries would last about an hour....with 4 ea 26AH wired in series for 48v....
http://www.falconev.com/E-Bikes.html
03/04/2014 1:17 PM
Provided the motor is strong enough to move the vehicle at all, at the required weight, speed, gearing, Drive train resistance and so forth, but yes basically Bat watts / motor watts.
03/04/2014 2:15 PM
This company Ultramotor makes these electric bikes, so there should be a way to equate the specs given to what would be required....
http://www.amazon.com/A2B-Lithium-Electric-Ultra-Motor/dp/B0021IQP8A
03/04/2014 2:19 PM
Agreed.
Re: Specification of Electric Motor for Electric Bikes
03/05/2014 3:53 AM
hi - what is the type of motor which you are using?
03/05/2014 5:58 AM
Bldc motor
ee.saurav@yahoo.com
03/05/2014 1:39 PM
Register to Reply 8 comments
ee.saurav (1); LongintheTooth (3); satnat.2008 (1); SolarEagle (3)
