Previous in Forum: Specification of Electric Motor for Electric Bikes   Next in Forum: Starter Type for Big LV Chiller
8 comments
Motor Overloads
03/04/2014 3:23 PM
If a motor thermal overload is installed in a cooler environment compared to the motor, Will that cause the overload to trip earlier, If the question I asked is true, how do I go about compensating for that error.
The above motor is a 3 phase induction motor with no internal thermistor.
Re: motor overloads
03/04/2014 3:29 PM
No.
Re: motor overloads
03/04/2014 3:33 PM
A Thermal which is not installed in or near the device it is supposed to protect WILL NOT protect that device correctly.
Re: Motor Overloads
03/04/2014 4:37 PM
It will tend to trip later, rather than earlier. Depending on the specific overload relay design, you may able to compensate by using the next lower heater size, or setting the adjustment slightly lower.
Good Answers: 804
Re: Motor Overloads
03/04/2014 6:42 PM
There is no valid universal answer, it varies by each individual OL relay manufacturer, even by product within the same mfr's portfolio.
There are what are called "Ambient Compensated" overload relays in which case you need do nothing at all because they have a separate internal thermal sensor that adjusts the trip curve pick-up point in accordance with the relay ambient so that the trip curve is automatically biased to protect the motor.
Solid State overload relays are NOT based upon temperature at all, they SIMULATE the effects of temperature on the motor, but do so based SOLELY on the current flow through the sensor.
Then there are bi-metal "Ambient Insensitive" overload relays in which you need do nothing within a certain range, because the bi-metal element is designed to deform at a much higher temperature than others, so the effects of ambient are less important, but if your ambient falls outside of that range, typically -20 to 60 degrees C, you must take action (most IEC bi-metal overload relays fall into this category).
Then there are those that have no compensation, such as NEMA style bi-metal and eutectic melting alloy overload relays, so you need to very specifically do manual compensation, which itself varies by selecting different values of replaceable heater elements (if it has that kind), changing the dial setting, or adjusting a compensation setscrew.
RTFM.
Re: Motor Overloads
03/04/2014 7:12 PM
We seem to have more management material.
Good answer, none the less.
Re: Motor Overloads
03/05/2014 3:49 AM
If in case ,a bimetallic relay is placed in cooler environment compared to the motor - it is intended to give delayed trip . this bimetallic relay operates on physical expansion property of two metals , hence elogation of metal will be delayed in cooler circumtences.
Re: Motor Overloads
03/29/2014 11:21 PM
that's right!!!
Re: Motor Overloads
04/08/2014 7:10 AM
No it doesn't happen that way, current drawn will cause tripping of motor not the temp. so think technically not like environmental officer
Register to Reply 8 comments
Anonymous Poster (1); Apol (1); JRaef (1); lyn (2); navdeep_goyal (1); satnat.2008 (1); Tornado (1)
