Previous in Forum: Motor Overloads   Next in Forum: Peak Demand
8 comments
Starter Type for Big LV Chiller
03/05/2014 5:54 AM
Dear all,
Can we have DOL or Star Delta Starter for a LV Chiller (comprised of two compressors, where each is 248 KW) ? or Soft Starter is mandatory?
Please support with official catalogues/references/Standards,
Thanks
Good Answers: 445
Re: Starter Type for Big LV Chiller
03/05/2014 8:27 AM
Without any other information about the system supplying the chillers or their type, the answer is "yes".
For an official answer please support with more data and a wire transfer for consulting fees.
03/05/2014 8:46 AM
Motor soft starter - Wikipedia, the free encyclopedia
Centrifugal Chiller Fundamentals - Literature SearchMcQuay HVA
Low Voltage Starters
03/05/2014 8:52 AM
It depends upon the resilience of the upstream supply and cabling, no detail of which has been offered in the original post. So go with #1 above.
Good Answers: 804
03/05/2014 5:58 PM
Usually, the answer to this question is about regulatory compliance, not engineering. From a purely engineering standpoint, either one is an acceptable answer to "Can we..." Regulations will vary by location and are often administered by the servicing electric power utility through the permitting process.
If you are generating your own power, then it becomes an issue of the economic tradeoffs between having more generating capacity or more expensive starting methods.
03/05/2014 11:15 PM
Although DOL starting will result in higher starting current and higher voltage drop, nevertheless the starting torque developed by the motor will be higher. If the inertia of the driven equipment is high then there may be problem in starting (due to higher acceleration time or stalling) when you use a Star Delta Starter or Soft Starter because of reduced voltage at motor terminal.
Hence your decision will depend on the following:
- local regulation regarding starting of the highest rated motor
- short circuit level of the power network
- load inertia
03/06/2014 12:00 AM
Two out of three ain't bad.
03/06/2014 2:55 AM
Soft starter is advisable. Did you check the recommendations of chiller /compressor manufacturer?
Good Answers: 122
03/06/2014 9:59 AM
Most HVAC compressor units start "unloaded".
Other than possibly limiting the higher inrush current during starting which is only present for a brief period of time, I can't see any advantage to using a soft start.
Register to Reply 8 comments
debata07 (1); JRaef (1); lyn (1); mrswamy (1); PWSlack (1); RAMConsult (1); SHOCKHISCAN (1); Tornado (1)
