Previous in Forum: Air Operated Double Diapharam Pumps   Next in Forum: Design of Solar Powered Bench Grinder
Material Selection
03/12/2014 6:08 AM
Hi Every one,
We have process water degasser in sour service in petrochemical plant. we in the way to replace it with new one. the vendor that who working in fabricate select the following material:
for Shell and head: ASME SA 516 Gr. 60N
for Nozzel Flanges: ASME SA 105N
for Nozzel Nick: ASME SA 106 Gr. B/ SA 516 Gr. N/ ASME SA 105N
for your experince and knowledge, are these material suitable for the vessel
Design DATA are as follows:
- Design Pressure: 51 psi
- Operating Pressure: 20 psi
- Design Temp: 205 F
- Operating Temp: 160 F
Regards and thanks
Thanks I got the answer..
please delete the thread.
Re: Material Selection
03/12/2014 6:19 AM
What does the facility's Standards Manual say about the materials to be used for such a purpose? After all, the contents of such a document hold far greater value than the collected opinions of a bunch of Anonymous Posters Miscreants! :-o
Good Answers: 34
03/12/2014 6:20 PM
http://www.coleparmer.com/Chemical-Resistance
03/12/2014 6:38 AM
Please confirm that the vendor has been provided with a copy of the relevant section of the facility's Standards Manual as part of the enquiry activity.
03/13/2014 9:04 AM
Conan.. ASME Section VIII will guide you in the design of the vessel. For the service, you should refer to NACE MR0175 as well. The SA 516 Grade 70 material you list for the shell and heads is adequate, but you should source the plate as HIC treated plate. It will be vacuum degassed and Calcium treated during melting to reduce Hydrogen induced cracking during operation. The material is readily available. Pressure vessels we furnish for H2S service are fully radiographed per UW-51 and fully post weld heat treated after all welding is complete. I hope this helps you in your design.
Register to Reply 4 comments
PWSlack (2); Robert Johnson (1); Whitephone (1)
