Previous in Forum: Short Circuit Strength of Power Transformers   Next in Forum: Rulling Span of Transmission Line
Disconnect Contact Finger
03/13/2014 8:47 PM
In the context of breakers, Does anyone knows what a "disconnect contact finger" is and how does it works?
India - Member - New Member
Good Answers: 164
Re: Disconnect contact finger
03/13/2014 9:41 PM
In withdrawable breakers, there are seconday disconnecting contacts, which are 'off-load' to enable the ACB to be withdrawn for maintenance or other purposes. On one side, there is usually a bar contact while on the other side there are spring-loaded multiple-finger contacts. Here is an example.
Reply Good Answer (Score 4)
Good Answers: 131
Re: Disconnect Contact Finger
03/14/2014 10:30 AM
Here are a couple of photos to go along with the illustration you were given. Note that the spring-loaded fingers will mate with a flat bar type of bus contact. An alternative sometimes used is a tubular or cylindrical bus contact, with the finger cluster arranged in a circular configuration ("tulip").
Good Answers: 181
03/14/2014 10:38 PM
Sorry not a very good advert for rose (tulip) contacts but it shows what they are like.
Good Answers: 117
03/15/2014 10:07 AM
wow! Must have been an exciting lightning strike!
kvsridhar (1); PeterT (1); TonyS (1); Yusef1 (1)
