Previous in Forum: Does Vertical Take Off and Landing Have a Real Future?   Next in Forum: We Aren't Done Launching Just Yet!
42 comments
Brake Pedal Goes to the Floor
03/23/2014 12:02 AM
My brake pedal goes to the floor but the car still stops i got out and checked the fluid resivpur and guess what no brake fluid and my abdls and brake light are on so i filled it up with fluid drove it around thr block turned the engine off and guess what fluid was gone and pedal still goes to the floor so i went and added more brake fluid figuring that it being empty had no fluid now pedal goes to floor still and all the fluid is gone i didnt notice any fluid on the ground so where did it all go? And ehat do i do to fix this issue is it a master cylinder or a brake line im not sure this is a 1995 buick regal custom 3.8 please help me out not sure it has abs and also has 4 wheel disk brakes so please give me suggestions i cant afford a shop only myself so thank you all
Pathfinder Tags: abs light brakes master cylinder
Re: brake pedal goes to the floor
03/23/2014 12:18 AM
Take the keys out of the ignition and throw them as far as you can. Preferably into a neighbor's yard that has a big mean dog in it, BEFORE YOU KILL SOMEBODY!
Then, look under it for the fluid leak. Fill the master cylinder again, start the car, leave it in park, and push on the brake pedal. Look again.
Don't replace anything until you find the leak.
03/23/2014 12:32 AM
I have looked and dont find any leaks anywhere the only time it leaked is qhen i drove around the block cane back it was empty but i had someone in the car and added fluid and had them.press the brake pedal over and over again and no fluid leaked so i took it around the block again came back and bam empty again i think it is actually leaking on the naster cylinder itself if not idk what to say im about to replace master cylinder then the wheel cylinders and lines. If i still have the problem after all of this then i will be in a undecided situation.
03/23/2014 12:38 AM
Does it have power brakes? Did you see smoke coming from the exhaust? Can the engine be sucking the fluid out of the master cylinder through the vacuum booster?
You should see brake fluid on the inside of the tries if a wheel cylinder is leaking.
03/23/2014 12:49 AM
Yea i did notice a little bit of white smoke its wierd that you say that because it was not an oil leak nothing like that and it smelled different. And didnt see anything on the inaide of the tires.
Good Answers: 50
03/23/2014 4:36 AM
I believe Lyn is spot on where the fluid is going. The question now is how both seals were damaged in the master cylinder (as this is a dual system after 1965 DOT regulations required this). Was incorrect brake fluid used previously (like engine oil). If so a total system flush is required. Something has caused the seals in the master to fail, unless someone put sand in your reservoir. Out side of vandalism, the most likely cause is some other fluid that was not brake fluid.
DOT 2 and earlier is castor oil based. DOT 3, 4, 5.1 is glycol based, DOT 5 is silicon based. Main differences is boiling point. But there may be seal compatibility issues with wrong fluid, which turns them to mush.
ignator -
03/24/2014 9:28 AM
I have a 1990 Honda CRX that kept using brake fluid but I could not find a leak. Finally, with the engine running, I started pumping the brakes and after a minute or two white smoke started coming out of exhaust. The brake fluid was leaking out of the back of the master cylinder and filling up the brake booster. Then it got sucked into the engine.
Good Answers: 22
03/24/2014 12:46 AM
This is a possibility, I have heard of occasions where a booster failure can pull fluid out of the master cylinder, perhaps this is even likely, since apparently both halves of the reservoir emptied. Think of how the piston cups in the master cylinder are made. If a vacuum is pulled where the push rod goes in, the cup is designed to hold pressure, but a vacuum would put on the same stress as a differential of pressure. I don't see how it would leak, but it is not designed to operate that way. The reason I say likely is that it would be unusual for both sides of the master cylinder to have a leak suddenly at the same time.
An easy test. Fill master cylinder. Don't start engine. Mash on brake pedal many times and look for leak. If it is still full, the brake booster is probably bad, if it is empty look at the little switch that detects balance between front and back brakes or the area of the anti-lock brake mechanism if it has anti-lock brakes
03/23/2014 8:16 AM
if no fluid is present its in the vacuum booster
03/23/2014 8:45 AM
I would start with the master cylinder.
03/23/2014 8:55 AM
not all braking systems are the same
03/23/2014 9:55 AM
03/23/2014 1:53 PM
Its 4 wheel disk brakes in this model so it doesnt have any wheel cylinders i have checked just has bleeders directly on the brake so im pretty sure that if its the master cylinder i need to find out jow but also this vejicle is 19 years old and im only the second owner and thebfirst owner says never had this problem and qhen i teat drove it it was fine then the batterybdied and it sat for a day got a jump and vtakes were gone? Is it possible to have somethig to do with the electric?
03/23/2014 2:01 PM
You do have wheel cylinders, they just aren't called that. The caliper piston does the same job and can also leak.
03/23/2014 2:08 PM
O ok thank you bro that helped alot i honestly hope its just one of those and not the entire cylinder but im gunna go check this out now and let you all know exactly what it is i find out
03/23/2014 2:36 PM
I found the leak its between the vacuum and the master cylinder where they meet i noticed some fluid all over it does that mean i need to replacw the ebtire master cylinder or is there a gasket i can just replace also i am pretty sure it might be leaking around the resivour seal also? Please let me know ido not really know what im doing so does anyone know a shop i can afford this at i have about 400.00 to fix the problem?
03/23/2014 3:15 PM
We don't know where you are located. Usually in a place I don't know, I ask around from the locals for a good, cheap mechanic. It sounds like it is just the master cylinder. It should be under $400. Personally, I would buy the part myself because they charge double what it costs at a repair shop usually. Then you just need to pay for labor, which should be ~2 hrs max.
03/23/2014 3:31 PM
The fact that you had white smoke coming out the exhaust means the brake fluid is getting inside the engine, through the vacuum booster.
The master cylinder is relatively easy to replace, and cheap >$100.00.
The booster is more labor intensive and will cost the rest of your budget, if you pay to have it done. There are nuts under the dash, inside the car to take off.
Call around to non-dealer shops and ask what they charge to do both.
It's simple if you've done it before.
03/23/2014 10:23 PM
Well i found someone whois a mechanical engineer to help me out tomorrow afternoon i have my parts reserved at napa auto parts everything i need in parts is around 250 including booster cylinder and turn signal switch that is an entirerly seperate problem but after that is all done up with the car should be great she runs wonderful and only has 123k on engine and trans and i am only second owner and was owned by an older man that bought it brand new and did regular maintenance then it sat for 6 months because he couldnt drive i paid 900 for the car so a little work to have a great maintained car in great condition and almost no rust especially for a new york car thats almost 20 years old that amazing so thank you all ypu were a great help if it wasnt for this site i would have paid a mechanic out the wazoo for this
Re: Brake Pedal Goes to the Floor
03/23/2014 11:32 PM
Either it is burning in the engine, is leaking through the brake pedal rod into the foot well under the carpet of the drivers side or possibly ending up in the sump with the engine oil. Probably the first of these. If you can't see it leaking out anywhere then what else is there. Not having brakes is serious so I would get to the bottom of it before I had an accident.
03/24/2014 12:01 AM
I found the leak and i am not driving this vehicle at this time thanks for your advuse but please read pasr posts before putting in your two sence thanks
03/24/2014 12:42 AM
yes, I was half way thru the reply and got called away. By the time I got back and posted I discovered you had found it. After many years as a mechanic you could at least said 3 cents worth.
03/24/2014 12:00 AM
Michael, please let us know what you find.
03/24/2014 12:20 AM
I found the leak it was where the brake master cylinder and booster meet so i am replacing both the booster and master cylinder tomorrow afternoon got a great price on parts from napa auto parts all brand new the master cylinder is 85.05 abd the hydraulic booster is 79.99 so that is a great price compared to everywhere else once i replace them i will let everyone know how it goes but im sure that is the problem also i am replacing the master cylinder and resivour all with brand new not remanufactured parts as this is my familys life and other people life at stake everytime i drive down the road a car is a powerful and dangerous machine if not properly maintained and i am very well aware of this and when i took this car around the block i dis not go over 10 miles per hour and i would crash into a pole myself before i would hurt anyone else i do appreciate everyone help and concerns but i am a very responsible person and would never ever put anyone else in danger for my own desires i will keep everyone updated and as i have done brake repairs before just not a master cylinder i have replaced brake lines rotors drums and pads im sure this will be a new experience but not much more difficult than any other part of a vehicle especially a gm they are american and easy to work on from what i know thank you all for your time
03/24/2014 3:58 AM
This is a typical CR4 blog, someone needs some skilled help and advice and he comes to the right place and asks the right questions. Well done Mr OP.
Then there are a few here who know whats wrong and the best way to fix it. Its pretty obvious who they are, the usual crowd of clever people, very well known on CR4.
Then there are the "bottom feeders", who "think" they know something, but in fact they are just dangerous idiots.... those who don't have a clue!
The problem for the OP is how to tell one from the other!!!! Thankfully, in this case, it appears that he has done the right thing and ordered new parts. Well done Mr OP!!! But next time don't drive a car that sucks up its own brake fluid......if there is a next time!!!
Running the engine and pressing on the brakes a few times, with the park brake on, would have done the same.....
There is no accurate way really to sort out the good from the bad.....sady.
03/24/2014 8:34 AM
See i tried to just pump the brakes and it stayed at the same level it doeant loose the fluid until i drive it which is weird but im fixing it today
03/24/2014 9:46 AM
....you didn't have the engine running!!!
03/24/2014 6:37 AM
If it's not on the floor it's in the servo and will get to the inlet manifold then you will get a great white cloud come out the exhaust, the seals in the master cylinder have failed.
Bazzer.
03/24/2014 12:30 PM
Can't afford to not to take it to a shop if that's all you know about brake systems. I don't want to be harsh, but you need to start with simpler things, especially when yours and other peoples safety is at stake. I have a pretty good idea, but am reluctant to say because of the safety issue. Also not really a beginners project. Please, if you really cannot afford a shop, get some help, not just advice, from someone with a little more experience on brake systems. -- JHF
03/24/2014 12:58 PM
Maybe you need to READ BEFORE YOU OPEN YOUR MOUTH i have a mechanical engineer helping me and ive changed brakes before im not sure why people like you must put your teo cents in at all im doing what needs to be done it will be fully tested before droven any higher than 10 mph read old posts before you post thanks have a good day and to everyone else i will keep yall updated they will have the parts at my local napa store from 1:30-2:00 pm and im going to pick them up (not driving this vehicle fpr people who dont read past posts) and i got allnew brakes also to put in and will let everyone know how it goes if this fixes the issues i got the master cylinder the hydraulic booster brake pads and rotors turn signal switch thats all thats left but i just tried to start it and now it wont start
Register to Reply Off Topic (Score 8)
03/24/2014 1:12 PM
We like to keep members safe, him mentioning it twice or whatever is not a Cardinal sin.....
Stay cool and safe......
Remember, you wanted the help, you got the help. If it does not come as you like it, then go somewhere better for it please.....
03/24/2014 1:30 PM
Listen i dont need people to talk to me likeim dumb i got the help i needed i didnt need his two cents thanks though for yours also i got what i needed and THANK YOU ALL THAT HELPED but to those who want drama go on your facebook or something i dont get it i got what i needed why do people have to have drama on a car sight we should all be responsible adults and we KNOW how to be safe atleast I DO and as i have said in my previous posts i have a MECHANICAL ENGINEER helping me not only can he build a car he deaigns what you drive in everyday so please dont critisize he knows what he ia doing and i know how to do things ive replaced head gaskets brakes alot just never done this before or had this issue and when i did i blead the brakes and it was better so understand IM NOT A CHILD and pleade stop the drama
03/24/2014 5:24 PM
Look how many Off Topics you have already, this is a direct reflection of what people think of your manners here!!
NOT GOOD!!
We don't need you, just go......thanks in advance.
03/24/2014 6:58 PM
Thanks for yoyr advice but im good i had plenty of help until you came around buddy im good do you OWN THIS WEBSITE. NO your a nobody running your mouth go to another forum and run it buddy im not the one
03/25/2014 7:31 AM
Admin has been contacted.
We will let them decide what further actions may be required.
03/25/2014 10:23 AM
No duh i contacted them lmao you act like i cant make new accounts email adresses are free buddy thanks for your input there is also a freedom of speach law since i am an AMERICAN!
03/25/2014 1:24 PM
It appears that you are even less clever than I first took you for......you will need a new IP amongst other things.......
Also, may I suggest that using the spell checker may be a good idea too.....!
Ode to the Spell Checker.
(A bit of doggerel for the computer-literate.)
Eye halve a spelling chequer
It came with my pea sea
It plainly marques four my revue
Miss steaks eye kin knot sea.
Eye strike a key and type a word
And weight four it two say
Weather eye am wrong oar write
It shows me strait a weigh.
As soon as a mist ache is maid
It nose bee fore two long
And eye can put the error rite
Its rare lea ever wrong.
Eye have run this poem threw it
I am shore your pleased two no
Its letter perfect awl the weigh
My chequer tolled me sew.
I hope you like the humour!!!
03/27/2014 4:07 PM
First of all to andy this is a direct response to what you last said i do like humor so the last part did make me laugh but as far as the rest you must not know too much about computers if you get banned your ip address isnt banned the name you made and email adress is. Also yrs i might have some spelling errors because i dont spell check my post on a forums website for a few reasons, first of all i post on here using my cell phone and being a man my thumbs are a little big and the letters are small so i accidently hit the wrong button, second i have alot better things to do with my life besides checking spell checks on a forum yea it might be off a letter but if your smarter than a keyboard you know exactly what it means. So with that being said and everything else that has been saif on this forum i do not appreciate people on here bashing me for doing my own work because i cant afford the 600-700 dollars to put a part in my car that only cost 85.05 brand new and especially since i paid 950.00 for the car itself so go bash some rich guy who doesnt have any idea how to do anything or isnt mechanically inclined, because im positive it was not that hard because its done now and guess what works perfect might have took longer than the shop but i got it done. Now to everyone else who had helped me; Thank you all so much for your help it saved me alot of money and without all of you on this forum that did help me I honeatly do appreciate it and I wish the beat for everyone God Bless You All.
03/27/2014 12:03 PM
You have to get used to Andy.
He really does think he knows it all. He rarely offers actual advice which helps the OP.
He mostly pokes holes in the responses, tells the OP and/or the people who respond how dumb they are and how they probably, almost, killed the entire human race.
He'll then flaunt his supreme knowledge of all things on God's Green Earth. Again, without actually offering his own opinion or knowledge of the topic...usually. Just look how long it took him to sort out the responses on this thread. Then, regard his first response...negative.
Safety seems to be his biggest concern and he'll hit you with that hammer until you bleed. That's not the appropriate way, in my opinion, but hey it's a free world
You would think his tag line would mean more to him...
common knowledge...less common than common sense
03/24/2014 6:54 PM
So here is my new issue i got the master cylinder out and ita ok but it is connected to this box where the brake lines are that was on the side of it and there is only one bolt holding them togeather i unscrew it and can not disconnect the two and since in ny its cold as heck outside i brought it back inaide to try and disconect these two but the issue ia u dont want to try to take them apart if there is another bolt im missing and currently my friend is unavailavle for helping me so if anyone knows how to do what im asking please help me out thanks
03/27/2014 12:10 PM
Is this the part on the kitchen table?
03/27/2014 12:20 PM
Lol not anymore its now all back togeather n in the carvit was a abs modulator and if it wasnt hell getting the brake lines back in it because the bolts have to be just perfect or it wont go on mqchine threaded
03/27/2014 1:36 PM
yeah, had the same issue with my Jeep a while back. Everything has to line up just right.
Register to Reply 42 comments
4wsilver (1); Andy Germany (6); Bazzer Englander (1); Circuit Breaker (1); Dave864two (1); Fredski (2); ignator (1); lyn (4); michaelwunder99 (16); prof peanut (2); SolarEagle (3); SSCpal (1); The.Tinkerer (3)
