Previous in Forum: What is the Equivalent ASME Standard for UNI-ISO 4200 / Fe55-1   Next in Forum: Removal of Epoxy Paint
Bz Al Ni Alloy
03/25/2014 4:34 AM
What is Difference B/w BzAlNi alloy and B 148C 95800?
Re: Bz Al Ni Alloy
03/25/2014 7:01 AM
You appear to have invented a new material.
Did you mean: BAzAlNi
Find words within the letters 'bzalni' - More Words
Re: Bz Al Ni Alloy
03/25/2014 8:01 AM
B 148 C 91800 is a grade of Bronze,Aluminium and Nickel alloy.
Re: Bz Al Ni Alloy
03/25/2014 6:52 PM
Topologically, that statement would make B 148 C 91800 a member of the set of Bronze/Aluminium/Nickel alloys.
Re: Bz Al Ni Alloy
03/25/2014 9:55 AM
Bronze is an alloy of copper (Cu) and tin (Sn) itself. It has no chemical symbol.
Good Answers: 32
Re: Bz Al Ni Alloy
03/26/2014 10:39 AM
CDA 95800 is Alpha Nickel Aluminum Bronze, 81 Cu-5 Ni -9 Al - 1 Mn. Common uses are ship propellers and pump casings in desalinization plants where resistance to seawater is required. So technically they are one in the same but as noted Bz is an incorrect usage in the nomenclature. CuAlNi would be the correct terminology.
Spinco
Re: Bz Al Ni Alloy
03/26/2014 10:57 AM
Also "Naval bronze", perhaps.
Register to Reply 6 comments
JohnDG (1); lyn (1); PWSlack (2); Spinco (1); subair72807 (1)
