Previous in Forum: We Aren't Done Launching Just Yet!   Next in Forum: Which is Faster?
24 comments
Replacing a Brake Master Cylinder Difficulties
03/25/2014 10:29 AM
So i am replacing my brake master cylinder but in order to do so i had to take it out and what do you know connected to it is qhere the brake lines go and a computer but tyis part is a seperate part but they are attaches by one bolt that i can find so i took the bolt off and now i can not get the two parts seperated does anyone know where the issue is? Is the bolts i dont see? Or is it a seal that i need to seperate as im not sure first time doing a master cylinder its probably one of the only parts i havnt replaced on the brakes so i am in need of a little assistance anyone that could inform me would be greatly appreciated thanks for all the help. Also this part has 3 clip wires that i had to remove before pulling it out one with several pins on the bottom of it and then two smaller sensors near the brake lines on top the lines dont go durectly to the master cylinder.
Good Answers: 918
Re: Replacing a brake master cylinder difficulties.
03/25/2014 12:01 PM
Year, make, and model of the car would be a big plus if you would like help.
You might do a search for DIY brake cylinder replacement for your specific car on the web.
I am sure that we don't have to repeat that you need to be sure the brakes are correctly bled and working before test driving...
Re: Replacing a Brake Master Cylinder Difficulties
03/25/2014 12:29 PM
Take it down to your local Autozone....they will tell you what to do, and while you're there get a repair manual for your car....
http://www.autozone.com/autozone/parts/Haynes-Repair-Manual-Technical-Book/1995-Buick-Regal/_/N-j1e8aZ8gdxm?itemIdentifier=18322_1399_0_
03/25/2014 2:29 PM
Im on the way there as we speak lol and also its a 95 buick regal custom 3.8 4 wheel disk brakes and abs
Good Answers: 137
03/25/2014 12:59 PM
Do you think you could slow down, take a breath, and add a bit more punctuation? Then your post would be easier to read and you might get better answers!
And didn't you say in earlier post that you were going to take it to a repair shop?
03/25/2014 7:11 PM
No im npt taking it to a shop i have a friend that was going to come help me unfortanantly his wife had to have emergency surgery and he cannot be here until next week so im not driving as this part is obviously out of my car but it the brake master cylinder is connecter to some kind of abs brake modulator or somethig like this which it is connected to and there are no bolts on the outside connecting it so i have a new master cylinder to put in the car but i cant add it to the abs whatever it is becayse i cant get the old one off if anyone actually knows what the part im yalking about is since i got the manual for my car and it doesnt even say nothing about this part as if it doean exist i have looked it up and found it was some kind of abs controller that directly is hooked to the btake master cylinder somehow but i just need to kbow how they come apart so i can put them back on the bew one blreinstall and bleed the brake system after i put the new pads and rotors on thank you all whoever can actually tell me would be greatly appreciated
03/25/2014 7:39 PM
Does this look like the part you took out?
If not please post a pic....
...or does it look like this?
....or does it look like this?
03/25/2014 7:52 PM
The bottom one
03/25/2014 9:05 PM
That's a master cylinder assy from
1992 BUICK REGAL 3.1L V6 : Brake/Wheel Hub : ABS Hydraulic Unit
RAYBESTOS Part # ABS540070 Professional Grade; Reman
It's The Delco-IV ABS : (every year seems to be different)
http://www.rockauto.com/dbphp/x,catalog,27,partnum,ABS540070,d,RAYBESTOS_ABS540070.html
Has the ABS unit "attached to the side of a typical looking Master Cylinder"From: Rockauto.com
and this is the control unit for that assy
03/25/2014 9:14 PM
Nope its a 1995 buick regal custom 3.8 with 4 wheel disl vrakes and abs but i got it figured out and its off it has gears on the inside connected to 3 other gears and you have to take the plate off unscrew them and take them off them remove the bolts then reassemble obviously and i had it figured out thay someone put oil in the brake master cylinder pretty sure thats why this happebed so im gunna flush the system and then put it all back togeather thanks to everyone but im all done with this problem now on to the next one it was the bottom assemvly you showed me its differwnt
03/25/2014 9:16 PM
Thank you very much for helping me i appreciate it solar
03/25/2014 9:19 PM
ok.....report back for followup and let us know how it turned out....
03/25/2014 10:16 PM
10 4
03/26/2014 7:07 AM
If it was oil you will probably also have to replace the caliper seals or just go ahead and replace them with re-manufactured units, as it will soon or later get to the calipers.
Good Answers: 122
03/26/2014 10:45 AM
Michael,
In order for you to get help you must provide the make, year, and model of the car.
Be careful! The ABS components are expensive to replace and they are very sensitive so do not pry or hammer on the unit.
Good Answers: 22
03/26/2014 1:17 AM
On most modern brakes it is preferieble to bleed the master cylinder by itself using the 2 short plastic line that come with the master cylinder before installation. That is why the are included. I usually then quickly pull one of the temporary line and instal the brake lines before much fluid is lost. Then I crack one line at a time and have an assistant push on the brake pedal until the air comes out at that fitting. Then the other one. This way there is very little air in the lines. If it has antilock brakes, this make the total bleeding of the system easy. Antilock brakes of some designs can be a problem to bleed if not done correctly. It is very important to get a manual for the car before working on it. It usually saves a lot of money. I usually get an after market manual of a good brand and also the factory service manual for every car I own.
03/26/2014 4:42 AM
This man has posted twice for the same problems. He was very unfriendly to CR4 members previously. One reported him to Admin. If he is unfriendly to anyone, click on the report button....
He is mechanically deficient as well.
Register to Reply Off Topic (Score 13)
03/26/2014 4:51 AM
And you are boasting of being nice or what?
Hiding behind Anonym and personally attacking AP is very low on the scale!
Ashame on you!
Good Answers: 102
03/26/2014 5:17 AM
Strongly disagree.
Unless the OP sent a discourteous PM to some one then he seems OK to me.
I sense no mechanical aptitude deficiency. I sense someone with skills requiring guidance is all.
03/26/2014 5:59 AM
Dont feed the trolls
Good Answers: 102
03/26/2014 6:20 AM
That was for the OP's sake. He is new here and welcome.
03/26/2014 7:26 AM
One of the ways of solving problems like this is to list the vehicle on internet auction websites (names withheld). After a few days, someone shows up with some money, swaps it for the vehicle, and takes the problem away.
03/26/2014 10:07 AM
I just bought it last week and i like this vehicle also i know about "bench bleeding" the master cylinder and it is deffinatly getting done betore installation i may have forgot to say that. But i will do it and i know how to bleed the brakes well bleeding atleast and since it is connected directly to the abs modulator not the lines then it also has bleeders on the abs unit so you can bleed it directly from there and then thr lines. And as far as me being rude to a member here i wasbt rude and i dont have two posts for the same thing one is for figuring out the exact issue the second is fixing that issue its two different things and the guy who reported me was rude he said absolutly nothing to help me just made me not even want to use this website anymore because this is a forum not a social media sight thats why i used it if you dont have anything about the topic to say there is no reason you should say anything honestly and i reported him before he did me i absolutly love the people here that have helped me put because it saved me some money and i got the part all togeather inside its just about putting it in the car now but i live in upstate ny and its snowing and i dont have a garage so its freezing but it will be back in later today after my wife gets home from work. Also as i said before the brake master cylinder is directly bolted to the abs modulator or controller unjt which makes it a mjch easier bleeder because you bleed it bolt it directly on and then you can bleed the abs modulator before anything and you might not even have to bleed it at the actual brake lines because this should get all the air out. And for anyone who is concerned about safety i have done 100's of brake pads and rotors and drums before just never changed a master cylinder so trust me when i say this i know how to bleed the brakes and i have 4 children myself so before anyone of them go in my car i will make sure it is SAFE. Also as i had saud before my friend that is a mechanical engineer was going to come helpbut he couldnt because his wife had to have surgery she ia teeminally ill, so unfortanantly he could not come help but i do have a friend coming over that is a mechanic and has been for the last 32 years and he is coming saturday to fix my turn signal switch that needs to be replaced and im sure he will go over the whole car since im bringing it up to his shop to be inspected so thanks for all the help i will keep everyone updated on exactly how everything goes i will not use this siggt that oftrn after this once in a while i might check to see if i could also share my knowledge with other people as they have me. Everyone have a great day and thank those who helped and also those who stuck up for me when other people started things. And whoever made the "anonymous" post be a man post with ypur name and know what ypur even talking about before posting please i have explained this is a forum for knowledge this is not a facebook,or myspace,or twitter etc. You get the idea! Thank all the help people
03/26/2014 10:14 AM
The time to replace that keyboard has passed: it doesn't seem to have many functioning punctuation keys and many character keys duplicate letters or or are incorrect.
Good Answers: 22
03/26/2014 11:05 AM
Some of the people here can be very obtuse and not helpful. I would suggest that you start with an internet search for websites with owners from the same model of car or as close as you can get. If you state the exact model and year here someone might be able to help you, but you will have better luck with a website dedicated to that vehicle. I am sorry that some individuals were rude to you but they do not reflect all of us.
Register to Reply 24 comments
4wsilver (2); Anonymous Hero (1); Anonymous Poster (1); cnc jim (1); Codemaster (1); IdeaSmith (1); LOCKDUKE (1); michaelwunder99 (7); PWSlack (2); SHOCKHISCAN (1); SolarEagle (4); Wal (2)
