Previous in Forum: Cable Conduit Requirement   Next in Forum: WIncc Scada Cannot Run Project
What Is Water Capacity Aluminium Cylinder?
03/27/2014 4:21 AM
In case of calibration Gas cylinder this term is often used .
Re: what is water capacity aluminium cylinder ?
03/27/2014 4:56 AM
Its how much water fits in the cylinder if all the gas is out!
You can also saw the cylinder in half measure all dimensions and calculate the volume if you like!
03/28/2014 12:12 AM
thanks
03/27/2014 7:15 AM
I only answer this question on days that end with Y
Re: What Is Water Capacity Aluminium Cylinder?
03/27/2014 1:19 PM
12oz
03/27/2014 8:09 PM
The water capacity of a gas cylinder is the weight of water required to fill the cylinder to capacity.
03/28/2014 12:14 AM
thanks
Register to Reply 6 comments
Fredski (1); IdeaSmith (1); JE in Chicago (1); lyn (1); SUHAS227 (2)
