Previous in Forum: Pulsed High Voltage Current Sources for 600V and 1200V   Next in Forum: Wireless Question
Profinet or Industrial Ethernet?
03/31/2014 3:21 AM
Is there any difference between Profinet and Industrial Ethernet ? Same hardware is used for both ? Same softwares ? Thank you
...anything that can go wrong will go wrong...
Pathfinder Tags: Profinet Industrial Ethernet
Good Answers: 50
Re: Profinet or Industrial Ethernet ?
03/31/2014 3:58 AM
The only thing that might be different is that Profinet doesn't keep all the stuff that TCP/IP and Ethernet offers. For example, if you don't need TCP's connection oriented structure, why include it into the software.
03/31/2014 4:43 AM
If the same hardware and same software were in use, then there would be no difference.
Register to Reply 2 comments
