Previous in Forum: Connecting Lightning System With Earthing/Grounding System   Next in Forum: Design a Buck Converter
Earthing Truck
04/02/2014 3:06 AM
Why we use earthing truck in MV switchgear not in LV Switchgear?
Good Answers: 181
Re: Earthing Truck
04/02/2014 7:43 AM
For safety.
Earthing is a requirement for MV work to be carried out in most cases.
If earthing is required for LV it would normally be carried out manually.
Re: Earthing Truck
04/02/2014 10:36 PM
LV earthing is only for audio equipment or scientific signal processing and such. It is for shielding and noise control rather than safety.
Reply Off Topic (Score 4)
Good Answers: 22
Re: Earthing Truck
04/03/2014 12:13 AM
Some of the answers are misleading. MV or medium voltage switchgear, which is for 1100 volts AC to 15000 volts usually has normally got all the conducting surfaces taped or insulated so there is no way to put safety grounds on. The use a a good grounding truck or what some people might call earthing truck across the pond is used to ground usually the load side of the breaker. The best ones allow the unit to be racked in and the lack of power tested before a ground switch in the device is operated or manually engaged. The use of these devices require a good knowledge of the system to be sure that no backfeeds exist or someone does not rack them into a live bus. Deaths have occurred from error.
LV or low voltage switchgear can have voltages up to 1100 volts but are usually below 1000. This type of switchgear does not require taping of outgoing cables as a normal rule and it is a simple to thing to simply remove the back cover after de-energizing and locking out the feeder and installing grounding cables on the outgoing feeder before work is performed.
Re: Earthing Truck
07/24/2024 6:17 AM
It's a bit difficult to answer without talking to the <...we...> first.
4wsilver (1); Deefburger (1); PWSlack (1); TonyS (1)
