Previous in Forum: Redundancy   Next in Forum: Using Temperature Switches for Fire Detection
Accuracy Level
04/02/2014 3:27 AM
Electronic weighing accuracy level is third level, what does third level accuracy means?
I will explain a little background for you basically it is module for conveyor belt to measure material flow and display on screen.
Re: Accuracy Level
04/02/2014 4:42 AM
Can you quote the source and the exact module?
So far the information is not enough to even make a guess what is meant by this.
Re: Accuracy Level
04/02/2014 7:13 AM
It means that in the rest of the text that this one sentence was taken from that there are two other methods of weighing accuracy described.
Good Answers: 19
Re: Accuracy Level
04/02/2014 10:19 AM
Google 'weighing accuracy classes'
Good Answers: 153
Re: Accuracy Level
04/03/2014 4:02 AM
First level accuracy is the national standard kept in environmentally controlled conditions by your equivalent of the National Standards Authority.
Second level accuracy are the weights used to calibrate your scale. These will have been tested against the national standard and will have a dated certificate to prove it. Usually these weights need retesting every one or two years.
The third level accuracy is your scale. Minor discrepancies are introduced each time one weight is calibrated against another weight or in your case a set of scales. There are many other causes of discrepancy to your material flow reading, and provided the scale is calibrated regularly, typically once per year, and zeroed regularly, typically once per month, you will display a material flow that is within most industrial tolerances. Some industries such as pharmaceuticals are special cases and require extreme tolerances but they don't weigh materials on belt conveyors.
Re: Accuracy Level
04/03/2014 5:06 AM
Dear Mr.muhammafarhan.
I think the third level accuracy refers to accuracy in 3rd Decimel.
DHAYANANDHAN.S
Bud (1); dhayanandhan (1); IdeaSmith (1); jhhassociates (1); redfred (1)
