Previous in Forum: Nigeria - National Building Code - Wind   Next in Forum: Loads on Transmission Towers
8 comments
Time Lag Insulation
04/03/2014 2:42 AM
How do I calculate the time lag of 4 cm of EPS insulation?
Thanks
Pathfinder Tags: EPS insulation Time lag
Re: Time lag insulation
04/03/2014 2:52 AM
Look at its thermal conductivity.
If I understand your question.
04/03/2014 3:17 AM
I would like to calculate the time delay due to the insulation, taking into account an external temperature of 32°C and 20°C inside a room.
04/03/2014 3:44 AM
Yes! Thats why you need to look at your conductivity!
04/03/2014 8:50 AM
on what? a wall, a pipe, what?
04/04/2014 2:37 AM
on a wall.
Good Answers: 183
04/03/2014 10:01 AM
This would be the answer if you would consider a steady state process.
It is a dynamic process so that the parameter to be considered is the thermal difusibility.
It takes into consideration not only the conductivity but also the capacity to accumulate (store) heat as product between "cp" and the specific mass of the insulation stuff..
As for the equations they are in almost all books about heat transfer. I use among other the Lienhard latest version (written by the son) which has the advantage to be free for downloading.
Good Answers: 445
04/04/2014 12:23 PM
Great book, thanks for pointing us to it!
Re: Time Lag Insulation
04/03/2014 4:58 PM
Oh, easy. Read-up on heat transfer in something like "Fundamentals of Heat, Mass and Momentum Transfer" by Welty, Wicks & Wilson and apply the contents. It's a book, BTW.
Register to Reply 8 comments
df (2); Fredski (1); IdeaSmith (1); lyn (1); nick name (1); PWSlack (1); RAMConsult (1)
