Previous in Forum: The Cheerio Effect: Why floating stuff clumps together   Next in Forum: Google cache thwarts Orwellian move by Feds
Friend of CR4
Replacing my water heater - advice needed
09/22/2005 11:58 AM
Well, the 1956 Alcoa Alloy, "Atomic" water heater in my basement is finally giving up the ghost. It can't hold a constant temperature and has a tendency to shoot out scalding water followed by extreme cold. Since there are only two of us in the household, its not being over worked; its just well past its useful life and certainly not energy efficient.
With the predictions of high natural gas prices this Winter, I'm wondering if anyone has experience with Demand Water Heaters. The technology sounds good and any costs savings are a benefit, but I always like to hear from folks who have used a technology before I make the jump.
And for those of you who are technology historians - Alcoa Alloy is now know as Aluminum, and the water heater is not nuclear-powered, "Atomic" in this case is just a buzz word from the 1950s meaning powerful.
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
Demand Water Heater
09/23/2005 2:56 AM
Hello, I work overseas most of the year, and in most of the countries I have been the last few years this type of technology is used. I am actually considering changing my home in the USA to this type of water heating process. The only problem I have noticed is that in some cases (mostly hotels, or small apartments) you must reduce the water flow to maintain the temperature, but this is not consistant with all. I have contacted a friend who is currently living in Brazil where this is very common and he will forward some literature from the unit he just purchased Regards - Good luck
Re:Demand Water Heater
09/23/2005 9:11 AM
I have some limited experience with instantaneous electric hot water heaters -- and it has been bad. I have had elements burn out and the sophisticated electronic controls fail. Technical literature for the units I have looked at is sketchy at best. For an instantaneous heater you need a bigger electric circuit and will pay significantly more for the unit than a typical residential style storage heater. If you pay for electric demand, an instantaneous could result in higher demand charges and there is no opportunity to stagger demand with other equipment (i.e. if the air conditioning compressor is running lock out the hot water heater, with a storage heater you can run many minutes before the storage is used up, probably enough to finish you shower). Expect to replace instantaneous units on a regular basis. Also expect your model to become obsolete quickly.
Register to Reply 2 comments
