Previous in Forum: Binding Agent to be Used as Insulation in Ultra High Frequency Applications   Next in Forum: 362kv Substation Clearance and Bay Width
Location: crankshaft producing hub in belgaum,karnataka,india
Dielectric Barrier Compound for Plasma Electrode
04/07/2014 4:23 AM
We have manufactured an electrode for plasma generation, the life of the central copper conductor has drastically dropped down. We have used alumina tube of wall thickness 2.5mm through which a central copper conductor is passed, with a patented dielectric barrier powder.
Pl. suggest any other material to be used to improve conductor life and improve the efficiency.
Re: Dielectric barrier compound for Plasma electrode
04/07/2014 4:37 AM
Give it a rest. Two significant technical questions in a few minutes suggests that your staff is not capable of proper materials analysis or selection.
The generalities you list are not adequate for any proper analysis. You need someone to look at specifics, which you do not supply.
Yes, it will cost some money. Free, general advice will only confuse you further.
Pay someone to answer your technical materials questions.
04/08/2014 3:39 AM
Lyn, I agree :) He would need a material engineer to satisfy the quest to his query. A material engineer with design and superconductivity in depth knowledge. He must hire a firm to be specific. His product must not only be design accurate but show mechanical engineering tests of product strength and tensile? :) Mechanical test of strength and vibration...
Good Answers: 102
Re: Dielectric Barrier Compound for Plasma Electrode
04/07/2014 10:49 PM
Please provide a sketch of your electrode.
Do you really mean alumina aka aluminium oxide/saphire/corundum(which is already a dielectric) or do you mean aluminium (aluminum for you Yankees) for the said tube?
04/08/2014 8:02 AM
Try Iridium for your center conductor.Very high melting point.(2410 deg. C.)
Very hard and corrosion resistant.Superior to Platinum in some high temp applications.
04/09/2014 6:01 PM
You might try asking Eric Lerner, of Lawrenceville Plasma Physics about his DPF experiments!
What is that Cigarshaped object hanging in the sky ====>?
abasins (1); Cigarshaped (1); HiTekRedNek (1); lyn (1); Wal (1)
