Previous in Forum: Calculations for Testing Pressure Vessels   Next in Forum: Controller Output
8 comments
4-20mA pressure transducer
06/13/2007 4:03 PM
Does anyone know what the symbol for a pressure transducer is with a 4-20mA output?
Good Answers: 53
Re: 4-20mA pressure transducer
06/13/2007 8:23 PM
A circle containing the letters PT.
06/14/2007 9:32 AM
Do you know where I can get one with a 1/8 NTP male end? I am in Washington state.
06/14/2007 10:40 AM
Omega Engineering see at Web
Good Answers: 53
06/14/2007 11:54 AM
Yes I do, call MICONTROLS in Seattle. 800 877 8026
They are application experts, but for them to make a recommendation you will need to provide additional information.
What range do you need?
What materials do you need to be compatble with the measured medium?
What are the min and max temperatures that the transmitter will be exposed to?
What accuracy is needed?
Do you want a local indication?
Should it be adjustable?
Who are you?
Additional information may be needed.
06/15/2007 7:35 PM
Try with WIKA on this site: http://www.wika.com/WIKAWeb/Product/ProductDS.aspx
similani
06/18/2007 4:49 AM
Rosemount and Honeywell are two manufacturers worth a look (usual disclaimer). Their sales teams can offer transmitters configured with a wide range of inlet connections. Even in Washington State.
06/14/2007 11:59 AM
Omega is the probably the best reseller to go through. My former employer, Kavlico Corp. is a leading manufacturer of pressure sensors and has been known to sell individual quantities. They have a PT255-(pressure range) with an 1/8" NPT port and 4 to 20ma output.
A little side note: Transducers tend to be voltage output, whereas transmitters are current output. Comes from the fact that generally the transduction tends to be through mechanical deflection of a capacitive plate or strain against a Piezo Resistive device and converted into a voltage output. The manufacturer will then add a voltage to current converter board for current output in applications where long transmission of output is required, hence transmitter.
Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Automotive Engineering - ChemE in a ME world
06/14/2007 3:03 PM
I had a lot of success with Rosemount
No matter how far you have gone down the wrong path....Turn around!
Ace Boeringa (2); Anonymous Poster (1); christian101 (1); PWSlack (1); similani (1); Sonave Sunsets (1); Yani (1)
