Previous in Forum: Ready For 78MPG?   Next in Forum: Help with 1999 Pontiac Bonneville
17 comments
1998 Cavalier Won't Start When it Rains
04/14/2014 8:25 PM
I have 1998 cavalier that seems to have developed and allergy to rain. When it drys up so does the car then it starts fine. Otherwise there's no fire at all when it rains. It needs a tune up so I've gone that route with new plug wires etc. No code at all being thrown and from what I understand it shouldn't be the ignition coils. Anyone have any other ideas?
Re: help
04/14/2014 8:55 PM
Air, fuel and fire.
Can you hear the fuel pump run when you turn the key to "on"? Does it stop after 2-5 seconds?
Do you have confirmed spark?
Air, I don't think it's that.
Gotta think wet wiring, connection is causing the problem.
Maybe check some Cavalier forums.
CR4 only comes up because so many lost souls come here for solace.
Re: help
04/14/2014 9:03 PM
Yep fuel pump is fine. It seems at some points it wants to fire then goes i see others suggested new plug wires. I'll try that tomorrow. There was moisture everywhere and i hadn't driven it yet. Very damp conditions. Started right up twice after it dried off.
Re: help
04/14/2014 9:06 PM
spray this all over the cap and wires, it will start safely
Re: help
04/14/2014 9:12 PM
THERE'S no cap just coils but I got what you're saying. Someone else suggested the same.
Re: help
04/14/2014 9:15 PM
its a WATER DISPLACEMENT spray, it really works
Good Answers: 918
Re: help
04/15/2014 9:20 AM
One trick is to start it at night in a dark place, open the hood, and use a spray bottle of water to mist the engine compartment.
If it is an electrical problem you will see it as it manifests itself as blue arcs at the source of the problem.
My bet is also the wires as the high voltage is easily bled away if there are any imperfections in the wire insulation.
Low voltage connections are not nearly as susceptible to moisture.
Re: 1998 Cavalier Won't Start When it Rains
04/14/2014 9:00 PM
consider yourself lucky. most owners of these cars get stranded far from home. your car is doing you a favor.
04/14/2014 9:06 PM
It's probably a ground wire not making a good connection....trace em out, clean em off, use some dielectric grease on the connection...I would start with the battery connections....
04/14/2014 9:14 PM
I was thinking the same thing right after I posted. Thank you
Good Answers: 94
04/16/2014 4:01 AM
One way to check is to use a jump start lead from the engine block to the battery ground, see if that improves things.
04/15/2014 12:41 PM
Internet auction sites are great for solving problems like this. One simply lists the vehicle with a photograph, and a few days later someone shows up with some money, swaps it for the vehicle, and takes the problem away.
Good Answers: 25
04/16/2014 9:01 AM
Check the wiring harness going to the crank position sensor; the insulation deteriorates, allowing the wires to short-circuit when they are wet.
04/16/2014 11:00 AM
Don't know what kind of ignition you have, but the pickup in the distributer or cranckshaft position sensors are possible problems: Been there done that
04/16/2014 4:06 PM
I had a 1994 Pontiac Sunbird that did the exact same thing after four trips to the service garage and nearly in a fist fight with the service manager for changing only one spark plug wire each time, I went to another dealership service garage and had it fixed in about an hour. It ended up being the ignition module/coil pack had a hairline crack in it.
Good Answers: 123
04/21/2014 1:02 AM
I don't think you want to throw every part that has been mentioned so far into the car. Do the overdue routine maintenance. Plugs and wires. If the issue continues, use the dark night method to look for spark jumping. It helps to put a load on the engine, so back it against a tree, or wall, and leave it in reverse. parking brake full on. Once you identify any arcing issues, WD 40 will dry them out, But spraying clear lacquer on the parts will seal them well against water intrusion. Just respray it every 3-4 months. Do it to a hot engine with the engine off. Allow overnight to dry well. One spark will ignite the wet lacquer.
Bob
05/02/2014 5:55 AM
That's what I did and that's what it was..lol Plug wires. Its also took care of a secondary issue that I was having. it seemed like it was missing but I am betting it was arcing instead thanks all.
Good Answers: 123
05/16/2014 1:55 AM
Another satisfied Cavalier owner.
Bob
Register to Reply 17 comments
Anonymous Hero (1); bob c (2); dery2026 (1); Ed Watts (1); Fredski (3); KeepItSimpleStupid (1); lyn (1); Nigh (1); PWSlack (1); silverfox41969 (4); SolarEagle (1)
