Previous in Forum: Thread Pull Out   Next in Forum: Petroleum Casing Pipe Heat Treatment
Iterative Solution Using Casio Calculator
04/16/2014 6:38 PM
I want to know how to solve transcendental equations using a casio calculator. I need a solution to the secant formular on buckling of columns. I'm a university student in nigeria. any help at all would be appreciated.
life is a rollercoaster
Pathfinder Tags: iteration
Re: iterative solution using casio calculator
04/16/2014 6:50 PM
Re: Iterative Solution Using Casio Calculator
04/16/2014 7:09 PM
Many Casio calculators do have trigonometric functions. You could do a Taylor series of the secant function to calculate the secant. There's also the obvious fact that you have internet access. There are many trigonometric calculating web pages.
04/16/2014 7:39 PM
There are a million (transcendental exaggeration) Casio calculators.
A little specificity will help.
Solving equations with the CASIO FX-991ES calculator - The Student
Good Answers: 137
04/17/2014 3:30 PM
Can't you do it on XL? You need to go XL options/formulas and check the Allow iterative calculation box (otherwise you'll get a circular reference message).
Good Answers: 444
04/17/2014 6:52 PM
Why are you going through all that trouble? Surely you know that the secant is simply the reciprocal of the cosine, so use the cosine function on your factors and then use the reciprocal key on the result for your answer.
04/17/2014 7:11 PM
It is good to know about the Taylor series. It is the iterative calculation of the Taylor series that most trigonometric calculators do in the background when one presses those trig keys.
Good Answers: 137
04/18/2014 5:36 AM
What equation are trying to solve? From a quick look on the web the equation I found can be solved directly, as per RAMconsult in #5.
You only need iteration if you have θ and sec θ in the same equation (and you're trying to solve for θ)
Register to Reply 7 comments
Codemaster (2); lyn (1); RAMConsult (1); redfred (2); SolarEagle (1)
