Previous in Forum: Diffe. Between Solar Panels V/S Building Integrated Photovoltaic Products   Next in Forum: Energy Meter Running With Neutral Wire
Transformer Load Reaction
04/18/2014 10:47 AM
In 3 phase 11KV/440V,1000KVA Transformer,connected load only 100kva,(means 10%).only.In such conditions,What will happend in the Transformer and it will react to powerfactor or impedance or else?
Good Answers: 445
Re: Transformer load reaction
04/18/2014 12:24 PM
The only time a transformer "cares" about the load is when the load is greater than the the rating. So if you load it to only 10% of its rating then it will just pass the power through with no problem. The power factor on the high side will be be the resultant of the high side voltage and the current as it passes through both the load impedance and the transformer impedance, with a small voltage drop through its internal impedances.
04/19/2014 12:37 AM
Thankyou
04/19/2014 8:15 AM
At 10% check the output voltage,if high adjust off-load tap.
pnaban
04/19/2014 8:34 AM
At 10% load, the cable losses will be 1/100 compared to full load, Guv, so who gives a monkeys about power factor!
Good moaning!
Register to Reply 4 comments
Crabtree (1); pnaban (1); rajanbt (1); RAMConsult (1)
