Previous in Forum: MEMS Gyroscope bias drift correction?   Next in Forum: Electrostatic precipitator
Contactor Replacement Question
06/14/2007 9:17 AM
E. P. DC CONTACTOR SPECIFICATION
MODEL: TSW-96EP-2SS (Dual Power Supply) 05/03
TYPE: DC explosion proof starter contactor for single BE frame starter
motor with dual power source, 2 contactors per enclosure, with
push buttons for local starting
WIRING DIAGRAM
REFERENCE: WI-565
ENCLOSURE Class I, Div. 1 & 2, Group C, D; Class II, Div. 1 & 2, Group E,F,G;
CERTIFICATION: Class III
UL Listed – File E10514
CSA Certified – File LR11716
VOLTAGE: 24 VDC contacts; 24VDC coils, 2.0 amps pull in.
AMPERE CAPACITY: 3000 inrush, 1600 cranking, per contactor
GROUNDING: None
ACTUATION: Push button switches mounted on enclosure for local starting. Use with
customer supplied remote switches.
SWITCH TYPE: Magnetic, SPST, double-break design rated for 1 million
electrical cycles, silver contacts, 5/16-18 terminal mounting bolts.
ENCLOSURE Body – Cast copper free aluminum alloy with 1 ea. ½" NPT
CONSTRUCTION: threaded hole, 3 ea. 1¼ " NPT threaded holes.
Lid – Cast copper free aluminum alloy, threaded, cover opening
9¾".
DIMENSIONS: 12" L x 11"W x 8¼" H
MOUNTING: 7/16" holes, 4 places
SHIPPING WEIGHT: 53 lbs.
Hi mates
all above spec for contactor of starter for Diesel fire fighting pump
Regardless of safety is it possible to replace this contactor by normal 20Amp contactor
Good Answers: 804
Re: Contactor Replacement Question
06/14/2007 10:59 PM
No, you cannot replace ANY component in a fire pump controller without violating the UL listing, and if there is a fire and the pump fails and an insurance adjuster finds that, your insurance may become nullified.
06/15/2007 5:15 AM
Absolutely not, apart from the legal and liability problems, a standard 20A contactor would never tolerate this duty. The contacts would probably disintegrate at the first operation due to the DC in inrush current.
There would also a be a real danger of the contactor contacts welding together, preventing the starter from disengaging.
Further in most countries installing uncertified electrical equipment in to an explosion proof situation is a a criminal offence, with the ultimate possibility of gaol.
06/18/2007 4:03 AM
Thanks but still my question in technical what the problem only inrush current and if I found DC motor contactor is it be fine ?
07/10/2007 7:43 AM
Not to belittle the liability issues, but most components that are mounted inside of the exsplosion proof housing are often standard parts. It is the enclosure that has to meet the ratings not the individual devices "inside". So strictly from a practical sense if you can find a contactor with the right ratings and it fits onto the space in the enclosure, you should be ok. But checking with your local inspector in writing would be a good idea.
Good Answers: 804
07/10/2007 11:18 PM
"... but most components that are mounted inside of the exsplosion proof housing are often standard parts."
Irresponsible posting.
You are focusing only on the issue of it being in an explosion proof enclosure. IT IS A FIRE PUMP CONTROLLER!!!! You should NEVER mess with re-engineering ANY component within a fire pump controller. You have NO IDEA what the consequences could be, and if you make a mistake, YOU ONLY FIND OUT WHEN YOUR FACILITY BURNS DOWN!!!!
You might be interested in: Threaded Inserts, Enclosure Air Conditioners
