Hello, I could not understand what this paper means with "harmonic voltage order 1st"??? and it is given also that it should not exceed the level of 6 % ... Have you an opinion?
With our consideration, we will choose harmonic order 1,3,5,7 because electronic equipment in Thailand have consisted of DC power supply, six‐pulse type. This equipment will generate the said harmonic order. However, we will revise some values of each harmonic order as below
:• Harmonic voltage order 1st not more than 6% (U1 = 6%)
Harmonic voltage order 1st not more than 6% (U1 = 6%) because most distributiontransformers of buildings or factories in Thailand are 22000 / 400V or 22000/415V.The voltage over 400V is hard to occur at main bus bar of Main Distribution Board........
