Assume a non-linear load connected to a voltage source delivering a pure sine voltage wave. Because of the non-linearity of the load, it will draw a non-sinusoidal current. This current will contain harmonics. Then is it really possible for the supply voltage to remain purely sinusoidal, since application of the ohm's law(or lenz's law for inductive load) for each harmonic current and superposition together will not give you a voltage equation that will finally add up to produce a pure sine wave?
